hotajax 285 #1 Posted March 31 Lots of choices out there, esp aftermarket blades. What do you think is the optimum thickness? Something that will let you put a long bevel on the cutting edge. Thanks. Share this post Link to post Share on other sites
rick 328 #2 Posted March 31 OEM blade thickness is .203 inch. Share this post Link to post Share on other sites
CobbyLebron 0 #4 Posted November 14 My original OEM blade measured at .203 inches as well, so that checks out fine for a standard starting point Share this post Link to post Share on other sites
peter lena 10,118 #5 Posted November 15 @hotajax regular for me , but never considered , how do related spindle bearings feel ? sound ? having done all my related bearings years ago , spindles , pulleys , pto / mule drive set up , pto cone needle bearing , another glairing hint is related BELT WEAR / FRAYING , CRACKING , ENTIRETY OF MOVEMENT , set up tells you what's going on , every related , cleaned out bearing , hand repacked with lucas x tra hd , GREEN CHASSIS GREASE , 550 deg flash point , polyurea rated , stays with bearing , fall , refitting is a great time for ELIMINATION OF REPEDITIVE ISSUES , also sun bake my decks , with lubrication , no rust / rot , pete Share this post Link to post Share on other sites
CobbyLebron 0 #6 Posted 5 hours ago I’ve used planer blades from planer blades before and they hold up well, so I’d guess a similar thickness around 0.203 inches works fine for mower blades with a long bevel Share this post Link to post Share on other sites
Gasaholic 402 #7 Posted 3 hours ago just curious but why is a long bevel desirable? 30 degrees is 30 degrees , length of bevel depends on blade thickness... but yeah thicker blades is nice insofar as getting a smoother cut (momentum due to heavier weight , greater rigidity..) cheaper mowers have thinner blades to save weight, cost, and be able to have longer blades while still able to maintain CPSC mandated blade stop times - less mass to get going and less mass to stop also helps belt life its all part of the engineering in building your mowers... But I see no real benefit to being concerned with bevel length otherwise... ? 1 Share this post Link to post Share on other sites
