mudmowerdiesel 236 #1 Posted March 31 Wheelhorse got the frame painted 6 Share this post Link to post Share on other sites
peter lena 9,885 #2 Posted March 31 @mudmowerdiesel nice job on that , question , are you going to lay in a steel 5/16/ steel brake line , entire frame length , inside upper corner of frame , for main fuel line ? eliminating a lot of fuel hose breakdown , only short clear fuel rated ends , from tank / carb , filter at each end , also like a fuel check valve just before engine , to show holding fuel verification. great spot to eliminate , repetitive problems , just an idea , pete 1 Share this post Link to post Share on other sites
mudmowerdiesel 236 #3 Posted March 31 31 minutes ago, peter lena said: @mudmowerdiesel nice job on that , question , are you going to lay in a steel 5/16/ steel brake line , entire frame length , inside upper corner of frame , for main fuel line ? eliminating a lot of fuel hose breakdown , only short clear fuel rated ends , from tank / carb , filter at each end , also like a fuel check valve just before engine , to show holding fuel verification. great spot to eliminate , repetitive problems , just an idea , pete It a diesel so no fuel line Go to the back the diesel tank is up front 1 Share this post Link to post Share on other sites
