mhvond 9 #26 Posted March 29 10 hours ago, Brockport Bill said: if you are looking for a 42 inch deck -- either side, or rear, discharge - - here are couple examples what they look like - top and bottom - these have been rehabbed -- the factory original pulley covers were red and the rear discharge model did not have the vinyl rear flange Do you have the model number for the 42" rear discharge mower deck? I believe I have the 42" side discharge as 5-1011 Thanks Mark 1 Share this post Link to post Share on other sites
953 nut 70,652 #27 Posted March 29 26 minutes ago, mhvond said: model number for the 42" rear discharge mower deck? Here are links to brochures on 42" RD decks https://www.wheelhorseforum.com/search/?q=42MR02&quick=1&type=downloads_file&nodes=18 1 Share this post Link to post Share on other sites
953 nut 70,652 #28 Posted March 29 31 minutes ago, mhvond said: I believe I have the 42" side discharge as 5-1011 That is correct 1 Share this post Link to post Share on other sites
mhvond 9 #29 Posted March 29 6 minutes ago, 953 nut said: That is correct Thank you Neighbor! I am just up the hill from you in Nantahala. 2 Share this post Link to post Share on other sites
ebinmaine 81,281 #30 Posted March 29 1 hour ago, mhvond said: We get up to Boston once or twice a year, Son and his fiance are there. I've got a solid but well used 42" SD for sale. It'll be available in Massachusetts around April 18th...ish. You could seriously consider having a deck from the PA Big Show in June brought down to you too. Several good options for you. 3 Share this post Link to post Share on other sites
953 nut 70,652 #31 Posted March 31 On 3/29/2026 at 11:26 AM, mhvond said: Thank you Neighbor! I am just up the hill from you in Nantahala. As the crow flies we are nearby, but as the roads twist and turn around and over the mountain passes it is quite a journey from Franklin to Andrews. 1 Share this post Link to post Share on other sites
