hotajax 230 #1 Posted 6 hours ago Tractor is 314-8. Front wheel has zerk sitting at a 45 degree angle, relative to the axis of the axle. I have to replace it because it won't take grease. Please note, this is not a zerk that was manufactured with a 45 degree angle. I am beginning to think that I screwed this up somewhere along the line. Have you guys ever seen the zerk going in at an angle? Or is the wheel trashed? Thanks. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,056 #2 Posted 6 hours ago If you have no success replacing the fitting you could plug the hole with JB Weld and replace the bearings with prelubed and sealed bearings that are now available. 2 2 Share this post Link to post Share on other sites
hotajax 230 #3 Posted 6 hours ago 1 minute ago, gwest_ca said: If you have no success replacing the fitting you could plug the hole with JB Weld and replace the bearings with prelubed and sealed bearings that are now available. Mr. Gwest: Do you have link to this part? Or better yet, know the part number? This seems like the break I need. Tired of removing the wheel just to lube the axle. Thanks. Share this post Link to post Share on other sites
wallfish 19,488 #4 Posted 4 hours ago 1 hour ago, hotajax said: Mr. Gwest: Do you have link to this part? Or better yet, know the part number? This seems like the break I need. Tired of removing the wheel just to lube the axle. Thanks. Just a quick net search so you might be able to find them cheaper but here's what you want https://www.ombwarehouse.com/sealed-ball-bearing-8273.html Share this post Link to post Share on other sites
peter lena 9,796 #5 Posted 4 hours ago @wallfish those wide rubber sealed bearings , make it easy to insure a known dependable lubricant , done all my similar / type / size , with , flush , a clean out, then lucas x tra hd green chassis , never had a bearing fail or whine , with that lube , every deck spindle , mule drive , bearings , pto related , never failed again, pete Share this post Link to post Share on other sites
Bill D 2,675 #6 Posted 3 hours ago Those grease fittings are tapped in at a 45° angle. All my tractors are like that. Share this post Link to post Share on other sites
sqrlgtr 2,293 #7 Posted 3 hours ago 3 hours ago, gwest_ca said: If you have no success replacing the fitting you could plug the hole with JB Weld and replace the bearings with prelubed and sealed bearings that are now available. I have been replacing all mine with sealed bearings. I like not getting grease all over my newly painted wheels, when I have newly painted wheels that is . 2 Share this post Link to post Share on other sites
