horseman with no horse
vanguard broken coil bolts
i went to take off the sad coil on my briggs vanguard and the one bolt snapped off. the other i worked back and forth till it came about 1/3 the way out and it also snapped. the one thats 1/3 backed out has about half an inch of shank poking out, and the first one has about 5/16 of the shank poking out. i wire brushed the shanks to get the rust off. should i just heat the pedestal post with a torch, use some penetrator oil, and double nut it? or is there a better way? this sucks as i was almost done with my build and if i somehow ruin the pedestals then the engine is ruined :(
also i used silicone on the side cover and i have no end play, does that mean i should get a gasket?
JoeM
Yep, Heat quench with penetrating oil. Let it cool before trying with double nuts. Might have to work both ways gently and no hurry.
Gasket on the end (sump cover) yes. I don't use anything but the gasket and I have a spring loaded punch used to put dimples )about every inch or so) in the aluminum on the engine. Helps prevent gasket blowout.
ri702bill
Excellent tip - if not over enthusiasticly done...
you guys are great thank you. i will keep you updated. i will probably attempt to remove it tonight.
SUCCESS!
Edited by horseman with no horse
should i use anti seize on the threats and base of the coil so this doesnt happen again?
or will the bolts rattle loose? im gonna be putting some decent rpm on her
lynnmor
Since it is unlike metals I would use anti seize, just don’t over tighten, the torque should be reduced because of the lubricant.  It would be a good idea to run a tap in the holes and use new bolts of the same or higher strength, and if you go a bit longer it would get you into better threads.
kpinnc
Absolutely. I would use it on all fasteners in that aluminum block.
And this is a good point. Especially on the bolts with higher torque values like the heads. Vanguard heads have some silly high torque values.
