MShepheard 8 #1 Posted March 23 Is it possible to replace the oil seal without removing the bearing plate. I have seen a method of removing the old seal with a self tapping screw threaded into a small drill hole and then it just being pulled out. I assume fitting the new seal would then just be a push fit ?? Any guidance would eb greatfully received. 1 Share this post Link to post Share on other sites
Achto 32,715 #2 Posted March 23 (edited) I have drilled a couple small holes in the side of the seal, screwed some screws into them, then used 2 vise grips to pull an old seal out. This only works if the outside of the seal has enough meat on it. Easy home made tool for installing them is a piece of PVC pipe that is the same outside diameter as the seal. They work great if you have to drive a seal back in with a shaft in place. Edited March 23 by Achto 2 1 Share this post Link to post Share on other sites
peter lena 10,065 #3 Posted March 23 @MShepheard https://www.google.com/search?q=packing+puller+tool&rlz=1C1CHBF_enUS866US866&oq=packing+puller+&gs_lcrp=EgZjaHJvbWUqBwgBEAAYgAQyCggAEEUY these make side seal pull removal easy , tiny hole , screw it in , pull it out , packed hundreds of vertical tank drives , agitator packing , smaller hole is better for snug screw in , pull out , also like silicone grease on grease seal to axel area , stops a rubber bind to axel , pete Share this post Link to post Share on other sites
MShepheard 8 #4 Posted March 24 Thanks for the replies guys, I'll give it a go and let you know. New seal should arrive tomorrow. 1 Share this post Link to post Share on other sites
MShepheard 8 #5 Posted March 26 The seal just would not come out , previous owner used something to make sure of that. Ended up taking the bearing plate off anyway as the crankshaft had a small amount of movement in it. Bearing is knackered, it was a +10 oversize. Shaft isnt took bad but now I'm wondering where I can get new bearings from in the UK ?? Share this post Link to post Share on other sites
lynnmor 9,040 #6 Posted March 26 3 hours ago, MShepheard said: The seal just would not come out , previous owner used something to make sure of that. Ended up taking the bearing plate off anyway as the crankshaft had a small amount of movement in it. Bearing is knackered, it was a +10 oversize. Shaft isnt took bad but now I'm wondering where I can get new bearings from in the UK ?? If no bearings are available locally, try eBay in the USA, search with your part number (101-0805-10?) and you will find several that will ship to you. Share this post Link to post Share on other sites
MShepheard 8 #7 Posted March 26 I had 101-0804-10 as the part number but it looks like either one produces results on ebay. Silly queston but should i replace it with the same +10 or given that the shaft must have worn by some amount so use a +20 ?? Share this post Link to post Share on other sites
lynnmor 9,040 #8 Posted March 26 6 hours ago, MShepheard said: I had 101-0804-10 as the part number but it looks like either one produces results on ebay. Silly queston but should i replace it with the same +10 or given that the shaft must have worn by some amount so use a +20 ?? You need to carefully measure the diameter of the crank and buy the bearing that corresponds to the crank . A crank won’t wear very much and you might have one that was ground .010” undersize requiring a .010” under bearing. The -10 at the end of the part number indicates a .010” undersized bearing. Share this post Link to post Share on other sites
