MShepheard
Onan P218 rear oil seal replacement
MShepheard
Is it possible to replace the oil seal without removing the bearing plate. I have seen a method of removing the old seal with a self tapping screw threaded into a small drill hole and then it just being pulled out. I assume fitting the new seal would then just be a push fit ?? Any guidance would eb greatfully received.
Achto
Posted (edited)
:WRS:
I have drilled a couple small holes in the side of the seal, screwed some screws into them, then used 2 vise grips to pull an old seal out. This only works if the outside of the seal has enough meat on it.
Easy home made tool for installing them is a piece of PVC pipe that is the same outside diameter as the seal. They work great if you have to drive a seal back in with a shaft in place.
Edited by Achto
peter lena
@MShepheard   https://www.google.com/search?q=packing+puller+tool&rlz=1C1CHBF_enUS866US866&oq=packing+puller+&gs_lcrp=EgZjaHJvbWUqBwgBEAAYgAQyCggAEEUY  these make side seal  pull removal easy  , tiny hole  , screw it in , pull it out  ,  packed hundreds of  vertical tank drives , agitator  packing  , smaller hole  is better  for snug  screw in , pull out , also  like silicone  grease on  grease  seal to axel  area , stops a  rubber  bind to axel , pete
MShepheard
Thanks for the replies guys, I'll give it a go and let you know. New seal should arrive tomorrow.
MShepheard
The seal just would not come out , previous owner used something to make sure of that. Ended up taking the bearing plate off anyway as the crankshaft had a small amount of movement in it. Bearing is knackered, it was a +10 oversize. Shaft isnt took bad but now I'm wondering where I can get new bearings from in the UK ??
lynnmor
If no bearings are available locally, try eBay in the USA, search with your part number (101-0805-10?) and you will find several that will ship to you.
MShepheard
I had 101-0804-10 as the part number but it looks like either one produces results on ebay. Silly queston but should i replace it with the same +10 or given that the shaft must have worn by some amount so use a +20 ??
lynnmor
You need to carefully measure the diameter of the crank and buy the bearing that corresponds to the crank . A crank won’t wear very much and you might have one that was ground .010” undersize requiring a .010” under bearing.  The -10 at the end of the part number indicates a .010” undersized bearing.
