MShepheard 1 #1 Posted 5 hours ago Is it possible to replace the oil seal without removing the bearing plate. I have seen a method of removing the old seal with a self tapping screw threaded into a small drill hole and then it just being pulled out. I assume fitting the new seal would then just be a push fit ?? Any guidance would eb greatfully received. 1 Share this post Link to post Share on other sites
Achto 31,213 #2 Posted 1 hour ago (edited) I have drilled a couple small holes in the side of the seal, screwed some screws into them, then used 2 vise grips to pull an old seal out. This only works if the outside of the seal has enough meat on it. Easy home made tool for installing them is a piece of PVC pipe that is the same outside diameter as the seal. They work great if you have to drive a seal back in with a shaft in place. Edited 1 hour ago by Achto 1 Share this post Link to post Share on other sites
peter lena 9,790 #3 Posted 51 minutes ago @MShepheard https://www.google.com/search?q=packing+puller+tool&rlz=1C1CHBF_enUS866US866&oq=packing+puller+&gs_lcrp=EgZjaHJvbWUqBwgBEAAYgAQyCggAEEUY these make side seal pull removal easy , tiny hole , screw it in , pull it out , packed hundreds of vertical tank drives , agitator packing , smaller hole is better for snug screw in , pull out , also like silicone grease on grease seal to axel area , stops a rubber bind to axel , pete Share this post Link to post Share on other sites
