Brockport Bill 2,553 #1 Posted March 19 the rustoleum paint cans suggest temps 55 plus and humidity below 55 %. There are a few days coming up with close to those thresholds -- but not perfect -- anyone know which is more critical -- the temp or the humidity? - if one is in margins but the other not? i can wait for warmer temps and proper humidity levels but am eager? 1 Share this post Link to post Share on other sites
ebinmaine 81,282 #2 Posted March 19 The BBT aka Paint Department is in the habit of spraying outside and immediately bringing the pieces INSIDE to dry. 7 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,921 #3 Posted March 19 I've had decent luck with that technique, but I ain't no BBT... 1 1 4 Share this post Link to post Share on other sites
Ed Kennell 47,946 #4 Posted March 19 I usually bring my paint and parts inside for a day before painting to get everything up to 70*. 6 1 Share this post Link to post Share on other sites
AlexR 3,139 #5 Posted March 19 (edited) I have been painting Rust-Oleum in the just below recommended temperatures and its been ok the biggest thing I noticed that causes problems is if the metal you are painting is pretty cold such as colder earlier in the day or the night before and hasn't warmed up enough it doesn't stick very well and gets runs easily. (If possible get the metal as warm as practical, the cans of paint also need to be kept warm) Also it takes much longer to cure. As to your question I would say it's definitely better to wait for both temperature and humidity to be ideal but humidity can cause a disaster if it's too high and the metal is sweating. I would not paint major sheet metal in less the ideal especially the hood, but the smaller parts you will probably be ok if you aren't looking for a perfect paint job. If you want the paint to be really good low humidity and 70° will make it easier Edited March 19 by AlexR 3 3 Share this post Link to post Share on other sites
Easton Rich 1,296 #6 Posted March 19 @AlexR said it best. Don't get impatient and paint while its cold. 2x the work. Make sure you lay thin coats if you're in the lower temp range. Just my 4 1 Share this post Link to post Share on other sites
kpinnc 19,107 #7 Posted March 19 2 hours ago, ebinmaine said: The BBT aka Paint Department is in the habit of spraying outside and immediately bringing the pieces INSIDE to dry. I do the same. 4 1 Share this post Link to post Share on other sites
ri702bill 13,394 #8 Posted March 19 Agreed - it still takes a month or so for it to cure enough for assembly... And use a trick from my old building model car days from 50 years ago. Warm the paint can in a pan of hot tap water. It raises the pressure in the can - gives a better finish. And it flashes off faster between coats.... 7 1 Share this post Link to post Share on other sites
ebinmaine 81,282 #9 Posted March 19 14 minutes ago, ri702bill said: month or so for it to cure enough for assembly... Our experience shows longer. Assembly.... very carefully. A few days. Cured? Man..... 2, 3 months or more. Even then don't expect auto paint type durability. 1 4 Share this post Link to post Share on other sites
Brockport Bill 2,553 #10 Posted March 19 wow - - great insights for the painting -- when i have been on the temp margin I have been bringing the item inside the garage 55-65 degrees plus turning on space heater to warm steel surface -- also I do warm the paint can in front of the space heater - never did the warm water pan tho as suggested ----- Always wondered tho if the paint "droplets" from spray actually get "cold" or effected by air humidity between can and before the spray hits the metal surface? For the humidity i have only marginally gone above 55% -- maybe 60-65 ish but never higher - However, per other comments above i have never tempted below the margins for anything I wanted to look nice like a seat pan or hood -- Not so concerned for a plow type project 3 Share this post Link to post Share on other sites
kpinnc 19,107 #11 Posted March 20 6 hours ago, ebinmaine said: Even then don't expect auto paint type durability. Given this alot of thought lately. Automotive paint is nice and holds a shine but can be quite brittle. What will make a scratch on many surfaces will chip on Automotive paint with hardener. Rattle can paint is softer, but most scratches are just that. With some work they can be repaired. I painted the V14 with rustoleum + hardener and it still is a bit rubbery several months later. I'm starting to like the durability of it. One thing to note: if your paint gets exposed to long term direct sunlight (think shed with open sides), rattle can won't hold up as well as Automotive. All my machines do some work. They just get exposed to a tougher life than what my truck gets. They get dirtier and far more scratches. At least I can make a decent (sometimes) repair on my tractors. 4 1 Share this post Link to post Share on other sites
953 nut 70,655 #12 Posted March 20 High humidity will slow the process of "offgassing" where the VOCs (volatile organic compounds) in the spray can become trapped in the pint causing it to blush. 1 1 Share this post Link to post Share on other sites
Retired Wrencher 7,043 #13 Posted March 21 When I was painting I used to take the parts up the second floor of the garage to bake in the hot temps. That was my work shop at one time because of two new vehicles and a boat. It got hot up there in the summer. Cured them well. 1 Share this post Link to post Share on other sites
