Gras 0 #1 Posted 4 hours ago Hello I have a problem with my C121. I started by changing the ignition switch because the old one seemed rusted at the electrodes, but it didn't change anything, then I bypassed the 3 safety switches (seat, PRO Interlock and pedal interlock), but still nothing. I now have a doubt about the ignition switch I installed, but I threw away the old one. How can I make sure that the one I put in is the right one? Thanks from France for your help Share this post Link to post Share on other sites
pfrederi 19,972 #2 Posted 3 hours ago Welcome If your engine has battery Points and coil ignition then one of the spade terminals will have an "I" the other will have S A R B if there is an M terminal you have the wrong switch. Bienvenue Si votre moteur est équipé d'un allumage à rupteur et à bobine, l'une des bornes plates portera la mention « I » et l'autre « S A R B ». Si vous voyez une borne « M », votre commutateur est incorrect. Share this post Link to post Share on other sites
Gras 0 #3 Posted 38 minutes ago Thanks a lot for the reply. How could I know of my engine has battery points and coil ignition ? Share this post Link to post Share on other sites
Gras 0 #4 Posted 37 minutes ago Just now, Gras said: Thanks a lot for the reply. How could I know if my engine has battery points and coil ignition ? Share this post Link to post Share on other sites
Easton Rich 1,040 #5 Posted 35 minutes ago You'd have a points ignition if you have a stock engine. This is what a coil looks like: Share this post Link to post Share on other sites
Gras 0 #6 Posted 25 minutes ago Yes indeed, I have a coil. Sorry for blunt questions : what is a points ignition ? Share this post Link to post Share on other sites
Gras 0 #7 Posted 22 minutes ago To help, which kind of photo should I share ? or which kind of info ? Share this post Link to post Share on other sites
Easton Rich 1,040 #8 Posted 19 minutes ago Its behind a cover that looks like this on the side of your engine Here is what the points look like: They mount under that cover Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,017 #9 Posted 18 minutes ago Click on the picture in this link. There are small pictures on the page that comes up. Click on one. They show what the back of the switch should look like. Share this post Link to post Share on other sites
