Gras 5 #1 Posted Sunday at 05:26 PM Hello I have a problem with my C121. I started by changing the ignition switch because the old one seemed rusted at the electrodes, but it didn't change anything, then I bypassed the 3 safety switches (seat, PRO Interlock and pedal interlock), but still nothing. I now have a doubt about the ignition switch I installed, but I threw away the old one. How can I make sure that the one I put in is the right one? Thanks from France for your help 1 Share this post Link to post Share on other sites
pfrederi 19,985 #2 Posted Sunday at 06:45 PM Welcome If your engine has battery Points and coil ignition then one of the spade terminals will have an "I" the other will have S A R B if there is an M terminal you have the wrong switch. Bienvenue Si votre moteur est équipé d'un allumage à rupteur et à bobine, l'une des bornes plates portera la mention « I » et l'autre « S A R B ». Si vous voyez une borne « M », votre commutateur est incorrect. 1 Share this post Link to post Share on other sites
Gras 5 #3 Posted Sunday at 09:18 PM Thanks a lot for the reply. How could I know of my engine has battery points and coil ignition ? Share this post Link to post Share on other sites
Gras 5 #4 Posted Sunday at 09:19 PM Just now, Gras said: Thanks a lot for the reply. How could I know if my engine has battery points and coil ignition ? Share this post Link to post Share on other sites
Easton Rich 1,051 #5 Posted Sunday at 09:21 PM You'd have a points ignition if you have a stock engine. This is what a coil looks like: Share this post Link to post Share on other sites
Gras 5 #6 Posted Sunday at 09:31 PM Yes indeed, I have a coil. Sorry for blunt questions : what is a points ignition ? 1 Share this post Link to post Share on other sites
Gras 5 #7 Posted Sunday at 09:34 PM To help, which kind of photo should I share ? or which kind of info ? Share this post Link to post Share on other sites
Easton Rich 1,051 #8 Posted Sunday at 09:37 PM Its behind a cover that looks like this on the side of your engine Here is what the points look like: They mount under that cover 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,020 #9 Posted Sunday at 09:38 PM Click on the picture in this link. There are small pictures on the page that comes up. Click on one. They show what the back of the switch should look like. Share this post Link to post Share on other sites
Gras 5 #10 Posted Monday at 09:06 PM Hello Indeed, I think I have the points. I also took a picture of the IDs. Thanks a lot for your help 1 Share this post Link to post Share on other sites
953 nut 64,403 #11 Posted Monday at 11:35 PM The AMP METER is sometimes a problem that is easy to overlook. Connect the two wires going to the meter together and see if that will resolve the problem. 3 Share this post Link to post Share on other sites
Gras 5 #12 Posted 10 hours ago Hi all Thanks to your help, I replaced the ignition switch by 2 simple switches and succeeded to start the engine. I know now that the ignition switch has to be replaced. I'll try to find a new one. Thanks again 1 1 Share this post Link to post Share on other sites
953 nut 64,403 #13 Posted 8 hours ago 2 hours ago, Gras said: I know now that the ignition switch has to be replaced. I'll try to find a new one. 103990 is the switch you need. Share this post Link to post Share on other sites
