ri702bill
C Series Hoodstand Corner Repair
gt14rider
Nice job.:USA:
Thor27
Excellent repair! Thanks for sharing.   I'd check out the F plate too as they seem to crack hand in hand.
ri702bill
Hopefully not as bad as this one from an 854...
Thor27
I bought (cheap) a 92 312H that the whole center was broken out, as well as both sides of the hood stand. I swear the only thing holding it together was the brake rod and belt. I drove it on my trailer that way, the front of tractor would rock with the whole range of motion on the front axle with both rear tires on the ground.
Bill D
6 hours ago, ri702bill said:
The C81 I picked up last summer had a common crack issue on one side at the back end of the Hoodstand where the Z shaped bracket, rear fenderpan and seat hinges bolt on. So didn't my parts donor tractor, but on the opposite side.... Looking down on the Hoodstand it is a 3 piece spot welded construction shaped like the letter "H". The solution was to split the left panel welds and do a mix-n-match of the better parts, reinforce those corners, and reassemble with pop rivets. I used 1/8" x 1-1/2" angle iron cut to shape and drilled for four plug welds each. This was easy to do with it split apart.... almost impossible to do together... I used the original hole for a nut & bolt and 2 pair of locking pliers for the fixturing.
Absolutely beautiful repair.
SylvanLakeWH
:eusa-clap:
kpinnc
Some very nice work there. Looks like it was originally built that way! :thumbs:
