brian h 0 #1 Posted October 1, 2009 Hello, I am thinking of buying a D-180 . The man wants $2k for it, it just had the hydrostat transmission overhauled and he sayed it costed him $2200 to get it done a few years ago do you guys think thats a fair price? it comes with a loader, rear rotoiller and wheel weights thanks Brian Share this post Link to post Share on other sites
rockbuilt 7 #2 Posted October 1, 2009 :scratchead: if the loader, tiller and tractor are in good condition that is probably not a bad price the loader itself is a rather costly item, no mention of a mower deck could set you back a few $$ also check to see how much is original to the tractor. good luck Share this post Link to post Share on other sites
d180man 5 #3 Posted October 2, 2009 Hi we have tide up more than that in one ! but we love the d's i say if it all works good and looks good or ok that is not a bad price from what we find around us ! but i know some may say just around $1500.00 but it is up to what you like to spend! good luck fill free to ask ?? if you need more help!! :ychain: Share this post Link to post Share on other sites
rickv1957 75 #4 Posted October 2, 2009 If overall condition of tractor and attachments is good that is a fair price,Rick Share this post Link to post Share on other sites
pfrederi 18,801 #5 Posted October 2, 2009 There are hydro rebuilds and there are hydro rebuilds....Test it and test it hard. Get it fully heated up and then try running the loader into a dirt pile..can you spin the wheels with weight box on the back?? How about up and down steep grades (in and out of ditches). The hydro is probably the weakest part of a D and overhauls (good professional hydraulic shop overhauls) are expensive. Also if it has been used much with a loader check over the steering very carefully for free play (Gear box, bell crank and tie rod ends). All are fixable but will cost $$$. also check the flat plate between the frame rails that the bell crank is bolted to. Heavy loads can bend it. If it has a loader it better have 1" spindles. Check the front axle pivot pin for looseness May be just teh pin (fairly cheap) or the axle housing itself...not so cheap for a 1" The hydro and steering lessons come from personal experience :scratchead: Share this post Link to post Share on other sites
brian h 0 #6 Posted October 2, 2009 Thanks, the overall tractor looks like it sat in the sun for a long time (stickers pealing off , etc.) lots of dusty oil underneath at the front and rear of tractor but monday I will drive it and check all the things you sugest. Thanks for the help, BrianH Share this post Link to post Share on other sites
