markseven 93 #1 Posted March 5 Wondering if anyone can give me a tip On installing a new diaphragm in the old Kohler 301 Original pump. Want to try and do it right so it doesn't fill The crankcase with a gallon of gasoline again. Share this post Link to post Share on other sites
Retired Wrencher 6,989 #2 Posted March 5 (edited) Quote Then and now have the best ones I have seen. Sorry i do not now the address or full site name. Quote Edited March 5 by Retired Wrencher Share this post Link to post Share on other sites
953 nut 69,303 #3 Posted March 5 prior to tightening the screws on the pump body clamp it in a vise and push the plunger rod all the way. This will properly position the diaphragm. 3 Share this post Link to post Share on other sites
ri702bill 13,063 #4 Posted March 5 1 hour ago, 953 nut said: prior to tightening the screws on the pump body clamp it in a vise and push the plunger rod all the way. This will properly position the diaphragm. Indeed. That pre-stresses the diaphragm to allow movement. Avoid this step & the diaphragm will tear.... 2 Share this post Link to post Share on other sites
pfrederi 21,150 #5 Posted March 5 https://www.thenandnowautomotive.com/antique-auto-parts-store/Kohler-Fuel-Pump-Kits-c196218002 Sorry but for less money you can buy a Carbole electric pump which many people here have used and never have to worry about gas in t crankcase again. If you want to spend a bit more get a made in USA Facet posiflo. 3 2 Share this post Link to post Share on other sites
sqrlgtr 3,930 #6 Posted March 5 All of the above. I found that the then and now diaphragms are on the thin side, but the only place I have found where you get the internal valves with kit. I started making an extra gasket to go in between pump body and diaphragm to keep them from leaking, even after stoning pump body halves to make flat, they were hard to get to seal up for me. Be aware there were a few different styles of pumps used so make sure you order the right one if you order a whole kit. Just turn diaphragm 90 degrees to remove. I had ordered a few diaphragms from isave tractors before he went out of business, and they were made with a heavier material and sealed up better. I have used the later plastic pumps also and have had good luck with them myself, but others have not. Share this post Link to post Share on other sites
peter lena 10,065 #7 Posted March 5 @markseven BEEN USING CARBOLE 2-3,5 PSI ELECTRIC PUMPS FOR YEARS added ADDED A led dash light to verify its function , my 3 horses have the same , problem eliminating set up ? fuel check valve , to hold and verify fuel to carb , filter and clear fuel rated hose to carb , showing you its there , also have filter just after leaving tank , went after every issue spot and eliminated it . try / test / verify . regularly make up something that lets me make a change , ( you already know what fails ) often staring right at you , also function detail in the throttle linkage ? is every movement spot smooth , easy moving / sliding ? like throttle / choke cable lubrication slide ? this is baseline stuff for me , that I evolved to , nothing sarcastic implied , just what I regularly do , pete 1 Share this post Link to post Share on other sites
WHX?? 58,125 #8 Posted March 5 Glass the halves and don't overtighten the screws is the best advice I can give. 2 1 Share this post Link to post Share on other sites
AHS 1,701 #9 Posted March 13 I am having trouble with rebuilding my fuel pumps… some work some do not! Ones that i rebuilt, I have had a fuel pump leak right between the halves… does this mean it’s bad? I have not tried the sanding yet. On 3/5/2026 at 7:21 AM, 953 nut said: prior to tightening the screws on the pump body clamp it in a vise and push the plunger rod all the way. This will properly position the diaphragm. Or this. I have put it in the vise (rebuilt), hooked a hose with gas in it between the outlet and inlet and pumped it. Kinda pre bleeding it. Share this post Link to post Share on other sites
Handy Don 17,474 #10 Posted March 13 (edited) 1 hour ago, AHS said: I have not tried the sanding yet. Mandatory. The pump bodies are relatively soft metal alloy and can definitely warp when the screws are overtightened. Also, “more” is not necessarily “better” in diaphragm thickness. What does matter is flexibility and tear-resistance over the long haul. Flat pump shell faces, positioning the pump to maximum displacement before tightening screws, and not overtighening are all keys to success. Edited March 13 by Handy Don 3 Share this post Link to post Share on other sites
