702854boy 1,199 #376 Posted June 23 (edited) @BlaineUpdate: The push rod I have is 1 1/2 inches long. If that will work for you you can have all of the stuff in the picture. If the push rod won't work you can still have everything else if you want it. Edited June 23 by 702854boy 3 Share this post Link to post Share on other sites
Blaine 276 #377 Posted June 23 10 minutes ago, 702854boy said: @BlaineDo you know how long of a push rod you need? I believe the small block is shorter than the big block push rod, i know the points are the same, and i’m only assuming the covers are the same also, but we’ll find out. Thank you. Original Kohler Part Number: 47 411 04-S (often replacing earlier 47 411 01-S or 47 411 01versions) 0.184 " in diameter and 1.550 " in length according to AI search Share this post Link to post Share on other sites
702854boy 1,199 #378 Posted June 23 (edited) According to my tape measure they measure the length you stated above, you can have them and see if they'll work if you'd like. Don't want anyone having to go home with a dead horse, thats happened to us before and its not very fun. Edited June 23 by 702854boy 2 Share this post Link to post Share on other sites
Blaine 276 #379 Posted June 23 I’m seeing closer to 1.250” on your tape measure… about 1/4” short. Share this post Link to post Share on other sites
702854boy 1,199 #380 Posted June 23 (edited) Yeah, I realized that after the fact that I apparently can't read a tape measure tonight. We do have a 14 horse that if i can get the push rod out of you can still have all of the stuff. Update, the push rod is not wanting to come out of the 14 horse but you can still have the points, condenser, and cover, and gasket, and screws to help narrow down your search. Edited June 23 by 702854boy 1 Share this post Link to post Share on other sites
Blaine 276 #381 Posted June 23 14 minutes ago, 702854boy said: the push rod is not wanting to come out of the 14 horse Is it rusted in place? Share this post Link to post Share on other sites
squonk 48,303 #383 Posted June 23 @Blaine I will dig through my big block parts. Maybe I'll have that rod. 1 Share this post Link to post Share on other sites
953 nut 70,204 #384 Posted June 23 8 hours ago, Blaine said: I may have a correct ignition switch to do the points ignition conversion That would be a 103990 ignition switch. This drawing will give you a start in the right direction. This is presuming you have a starter as opposed to a Starter / Generator. If you have a S/G we have a drawing for that too. 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,742 #385 Posted June 23 If anyone has a nice, original 1045 deck like this one shown (square style) I would be interested so long as price is fair. Thanks! 1 Share this post Link to post Share on other sites
Blaine 276 #386 Posted June 23 13 minutes ago, 953 nut said: That would be a 103990 ignition switch. This drawing will give you a start in the right direction. This is presuming you have a starter as opposed to a Starter / Generator. If you have a S/G we have a drawing for that too. Yes, it has the starter. Bushings in it were dry, so i cleaned things up in there and lubed it. Brushes are looking pretty short but it sounds like it’ll work for now. I’ll have to see if my switch is a 103990, but i don’t think so…i don’t think it has that many terminals. Things might pan out to be mowing with Whitey this weekend if i can find the 6908 drive pulley, a 1563 belt, and a side PTO in Ed’s buckets. Share this post Link to post Share on other sites
953 nut 70,204 #387 Posted June 23 4 minutes ago, Blaine said: I’ll have to see if my switch is a 103990, but i don’t think so Having been a breakerless ignition system on a '70s tractor it wouldn't have the five terminal more modern ignition switch. While at the show you can look for the 103990 switch and a "Pigtail" for it. 1 Share this post Link to post Share on other sites
squonk 48,303 #388 Posted June 23 30 minutes ago, Blaine said: Things might pan out to be mowing with Whitey this weekend if i can find the 6908 drive pulley, a 1563 belt, and a side PTO in Ed’s buckets. Belt is a 4L390 1/2" X 39" 1 Share this post Link to post Share on other sites
WHX?? 58,341 #389 Posted June 23 (edited) @Blaine @Achto and I used to shop here https://www.psep.biz/ and they had all the stuff for what you are looking for including the push rod. Haven't shopped there in awhile but was a good source for stuff. Edited June 23 by WHX?? 1 1 Share this post Link to post Share on other sites
Blaine 276 #390 Posted June 23 6 minutes ago, WHX?? said: @Blaine @Achto and I used to shop here https://www.psep.biz/ and they had all the stuff for what you are looking for including the push rod. Haven't shopped there in awhile but was a good source for stuff. Bookmarked. Thank you. Share this post Link to post Share on other sites
Pullstart 71,499 #391 Posted June 23 On 4/13/2026 at 2:23 PM, Pullstart said: I have some left over shirts from plow day. 4 size XL, 5 size L at the moment. $20 each. I have 3 Large and 4 X-L shirts packed. Any takers? 2 Share this post Link to post Share on other sites
Blaine 276 #392 Posted June 23 1 hour ago, 953 nut said: Having been a breakerless ignition system on a '70s tractor it wouldn't have the five terminal more modern ignition switch. While at the show you can look for the 103990 switch and a "Pigtail" for it. Sorry, i was referring to another switch i have, maybe from my long gone 867. It’s a 3 terminal that doesn’t use a starter relay. I’m not too concerned about a switch as i can work with what i’ve got. I could just add a hidden toggle switch to power the coil. Kinda like an anti-theft device. Lol while looking for the switch i found a side PTO, but it’s not slotted, no hole for the latch, and missing the pulley, so it could be made to work, but i’ll still need a latch also. Share this post Link to post Share on other sites
JoeM 10,317 #393 Posted June 23 I got a room at the Quality Inn not going to be used if anyone is interested, make an offer! It was prepaid none refundable, Thursday Night and Friday Night PM if interested. 3 Share this post Link to post Share on other sites
Bow_Extreme 584 #394 Posted June 23 On 6/20/2026 at 7:42 PM, c-series don said: Wheel weights, fit C-195 and some D-Series $200 PM Sent. Thank You! 1 Share this post Link to post Share on other sites
WildHorses 443 #395 Posted June 23 On 6/21/2026 at 11:51 AM, WHX?? said: I'll call dibs for my bird farmer shipmate Dan @Dan 312-8 if he wants it. He want it? I haven't seen any further responses. Share this post Link to post Share on other sites
Joshyg 41 #396 Posted June 23 11 hours ago, Blaine said: I believe the small block is shorter than the big block push rod, i know the points are the same, and i’m only assuming the covers are the same also, but we’ll find out. Thank you. Original Kohler Part Number: 47 411 04-S (often replacing earlier 47 411 01-S or 47 411 01versions) 0.184 " in diameter and 1.550 " in length according to AI search I believe i have the size you need 1 2 Share this post Link to post Share on other sites
Blaine 276 #397 Posted June 23 9 minutes ago, Joshyg said: I believe i have the size you need Perfect. Thank you. This being my first show and not knowing any names or faces, if ya’ll keep an eye out for me on Thursday, i’d greatly appreciate it. I’ll be the old bald guy with a ponytail in the Bahama Blue 54 F100. I’ll be wearing my matching “show shirt”. 3 Share this post Link to post Share on other sites
squonk 48,303 #398 Posted June 23 @Blaine I do not have that push rod Share this post Link to post Share on other sites
Joshyg 41 #399 Posted June 23 26 minutes ago, Blaine said: Perfect. Thank you. This being my first show and not knowing any names or faces, if ya’ll keep an eye out for me on Thursday, i’d greatly appreciate it. I’ll be the old bald guy with a ponytail in the Bahama Blue 54 F100. I’ll be wearing my matching “show shirt”. Ok I’ll bring it to the show and keep an eye out for you 1 Share this post Link to post Share on other sites
Blaine 276 #400 Posted June 23 Thanks. I’m looking forward to meeting everyone and putting some names and faces together. And thanks to the site admin and the WHCC for making all of this possible. And Mr Pond of course. Such a great community. 3 Share this post Link to post Share on other sites
