Handy Don 16,677 #201 Posted 7 hours ago Folding aluminum ramps. $90 ($75 to supporter member) The arch in the upper end keeps the mower deck from catching as the tractor reaches the trailer bed. 1 Share this post Link to post Share on other sites
cafoose 3,733 #202 Posted 5 hours ago Looking for a 5060 or a 5071 6-speed to swap into my 953 sickle tractor. Can't make it to the show. If @sqrlgtr is going maybe I can con him into bringing it back for me 1 Share this post Link to post Share on other sites
pfrederi 20,609 #203 Posted 5 hours ago Modified seat adjusters They slide freely. The holes in the spring to mount to the tractor are 7" OC....The holes on the sliders to mount the seat are 11-1/2 oc. $10 Share this post Link to post Share on other sites
Ed Kennell 46,128 #204 Posted 3 hours ago 17 hours ago, Blaine said: . So if one of the welded ones are about 16” from the flat of the bore area on the toothed side of the sector to the other end of the shaft, i should be able to make it work. The two welded shafts measure 20" end to end and 15.6" between the welded parts. 1 Share this post Link to post Share on other sites
702854boy 803 #205 Posted 1 hour ago Would anyone have the pieces that go under the gas tank and dash thing on the 60s square hoods? Share this post Link to post Share on other sites
Handy Don 16,677 #206 Posted 1 hour ago 3 hours ago, pfrederi said: Modified seat adjusters They slide freely. The holes in the spring to mount to the tractor are 7" OC....The holes on the sliders to mount the seat are 11-1/2 oc. $10 I'll take these, please. What is the range of travel on the locking slide? Share this post Link to post Share on other sites
Blaine 6 #207 Posted 12 minutes ago 3 hours ago, Ed Kennell said: The two welded shafts measure 20" end to end and 15.6" between the welded parts. Excellent. Will you be at the big show on Thurday? Share this post Link to post Share on other sites
