Tgalo 128 #1 Posted March 1 I bet this is already somewhere on the forum, but I can't find it. Anybody have a part number for a rear axle seal for a 520? The Toro seal is 22 bucks. Thanks, T Share this post Link to post Share on other sites
rmaynard 17,582 #2 Posted March 1 Hydro or 8-Speed? Share this post Link to post Share on other sites
rmaynard 17,582 #4 Posted March 1 (edited) 6449 (OEM) or 11124 aftermarket. Search Amazon or local NAPA store Edited March 1 by rmaynard 2 Share this post Link to post Share on other sites
Tgalo 128 #5 Posted March 1 Awesome, thank you very much Share this post Link to post Share on other sites
lynnmor 9,040 #6 Posted March 1 I have been using the pair of $14.54 6449 seals for Wheel Horse on eBay for years with no issue. Share this post Link to post Share on other sites
Tgalo 128 #7 Posted March 1 Let me ask, if I have a axle bearing problem, are parts available for these things? I have been building transmissions for over 40 years so I'm sure I can do this if I can get parts. Thanks,T 1 Share this post Link to post Share on other sites
pfrederi 21,146 #8 Posted March 1 (edited) Outer needle bearings are B-1816 Inner is a 40x68x15mm SKF 6008-C3 Edited March 1 by pfrederi 1 Share this post Link to post Share on other sites
Easton Rich 1,260 #9 Posted March 1 Ive got a complete seal kit somewhere for one, I'll try to find them if you're interested Share this post Link to post Share on other sites
ri702bill 13,045 #10 Posted March 1 Getting the hub off first may be easier having the gear oil migrate along under the hub over time... or, it may be a showstopper.... Share this post Link to post Share on other sites
Tgalo 128 #11 Posted March 1 Well, the hub slid right off thanks to the leak. It does have some radial play but how much is normal? Seems a bit much to me. The oil seems clean and I don't hear any noise when I rotate the wheel, its smooth. Going to put a seal in and see what happens. If it still leaks, I know I can get the bearings. Thank you pfrederi for those numbers, I'm going to order two of each as I have a bad feeling. T Share this post Link to post Share on other sites
pfrederi 21,146 #12 Posted March 1 Axle move in and out about 1/8" OK Axle move up down back forward at all bad news... 4 Share this post Link to post Share on other sites
Ed Kennell 47,296 #13 Posted March 1 8 minutes ago, Tgalo said: It does have some radial play but how much is normal? If you can feel radial movement, the bearings probably are going to fail. Best to replace before a ball ends up in the tranny. 3 Share this post Link to post Share on other sites
Tgalo 128 #14 Posted March 1 Yup, I agree, thanks again 1 Share this post Link to post Share on other sites
JoeM 10,267 #15 Posted March 1 1 1/8 axle with a new bearing will have .002 to .003 play 1 Share this post Link to post Share on other sites
Tgalo 128 #16 Posted March 2 Well, were going to find out. I pulled the transaxle off the tractor last night and will bring it into work and go through it. Definitely had more than .003 of radial play. Want to power wash it before I disassemble it. 3 Share this post Link to post Share on other sites
Tgalo 128 #17 Posted March 6 Got the unit torn down and clean. I have a pitted axle shaft but the radial bearings feel fine. Best place to find some good used axles? Thanks, T 1 Share this post Link to post Share on other sites
peter lena 10,064 #18 Posted March 6 @Tgalo personally always use , super lube , on any metal / rubber seal area , greatly ENHANCES , initial face off , prevents seal face roll / bind , often happens to a dry o ring replacement , ring bind , makes for , a failure , pete Share this post Link to post Share on other sites
lynnmor 9,040 #19 Posted March 6 A to Z Tractor might be the best source of axles. 1 Share this post Link to post Share on other sites
