peter lena 10,065 #27 Posted February 23 @Darb1964 think if i were getting a stand by gen today would definitely get the LPG bigger unit option , also relatively easy to get a transfer switch hook up installed , outside the house . did that many years ago , pete 1 Share this post Link to post Share on other sites
Wayne0 1,634 #28 Posted February 23 13 minutes ago, peter lena said: @Wayne0 all windows are like a frozen coral reef , that early AM RAIN just froze in place , just electric power shoveled , front of garage doors , that helped a lot , just a rolling auger , initial swipe , maybe half of snow depth , not trying for all of it , then then coming back with wheels on ground for second clear path . that double take is the way to go , makes it easier all around , another very evident issue , is over dressing when exerting , sense what works / does not . local weather says wind will not drop off till after 6 tonight , now that garage , is open , will try blower later , just a powered walk out the door , SHACKELTON , PETE I'm not even attempting anything until tomorrow. WAY too windy for the blower. I'd look like a snowman! 3 Share this post Link to post Share on other sites
wallfish 20,618 #29 Posted February 23 UGH, tension spring for the 520-HC drive belt idler broke this morning on round one of snow clearing. Fun stuff to go back out there and repair it in the middle of the driveway under these wonderful conditions. It could always be worse! Just got warmed up so heading out to tackle it. 1 6 Share this post Link to post Share on other sites
Sparky-(Admin) 26,359 #30 Posted February 23 Ariens blower first and a clean up after with the 520-8…no problems. Maybe 12” and it wasn’t wet/heavy like I was expecting. 7 9 Share this post Link to post Share on other sites
wallfish 20,618 #31 Posted February 23 Well it was a little worse. LOL The drive belt was frayed and noticed the inside loop edges would touch each other when that idler was pushed down. Got the belt changed but still need to do the idler spring. Came back in to warm up a little. And I couldn't tell where that spring connected on the arm. 1 Share this post Link to post Share on other sites
ebinmaine 80,695 #32 Posted February 23 Nearly zero snow here. Quite windy. We've been remaining on the far northern fringe of this storm. Share this post Link to post Share on other sites
wallfish 20,618 #33 Posted February 23 You know it's cold when you have to warm up the little propane tank with a heat gun in order to get a flame out of it! Used the torch to heat and re-shape that broken idler spring. Drive belt and tractor is back in business for now, although it will need some permanent attention when it warms up. 8 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #34 Posted February 23 3 hours ago, Darb1964 said: My sister in Bridgewater Massachusetts is without power, high winds and lots of snow. She said she can't see out of any of her windows. I have about 6 inches in the Berkshires of Massachusetts with little wind and light snow. Hopefully we don't get much more in the Berkshires we have enough for past storms. Darb you must have a big tractor with a bucket if I remember right. 1 Share this post Link to post Share on other sites
Darb1964 1,174 #35 Posted February 23 1 hour ago, Retired Wrencher said: Darb you must have a big tractor with a bucket if I remember right. Yes, I have the Kubota L 3010. That helps me keep the banks pushed back. 1 Share this post Link to post Share on other sites
Wayne0 1,634 #36 Posted February 24 Riding the storm out............ 2 2 1 5 Share this post Link to post Share on other sites
JCM 11,415 #37 Posted February 24 Retirement is a wonderful thing. 2 Share this post Link to post Share on other sites
wallfish 20,618 #38 Posted February 24 Got all the deep stuff done but scraping with the blade had to wait until tomorrow. This is what appears to be the spring location it was on but that doesn't look right to me. Like the notch was ground in to keep it from slipping but I'm assuming it should probably be connected somewhere else. Share this post Link to post Share on other sites
Sparky-(Admin) 26,359 #39 Posted February 24 This is my C-145…no pics of behind the idler 2 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #40 Posted February 24 13 hours ago, Darb1964 said: Yes, I have the Kubota L 3010. That helps me keep the banks pushed back. That good Darb. We are getting to old to be shoveling snow. Stay safe up there. Share this post Link to post Share on other sites
Retired Wrencher 6,989 #41 Posted February 24 10 hours ago, Sparky said: This is my C-145…no pics of behind the idler What’s going on here, Mike. Are you’re having a pulley problem or a belt problem. I see the fan is got a little eaten up. Hope you can fix it and get it ready for the next round of snow. Share this post Link to post Share on other sites
Retired Wrencher 6,989 #42 Posted February 24 18 hours ago, wallfish said: UGH, tension spring for the 520-HC drive belt idler broke this morning on round one of snow clearing. Fun stuff to go back out there and repair it in the middle of the driveway under these wonderful conditions. It could always be worse! Just got warmed up so heading out to tackle it. John I know you got more snow the we did. What was the final amount of snow did you get? Share this post Link to post Share on other sites
midpack 1,148 #43 Posted February 24 It's hard to judge the snow amount where I am. There's nothing on my deck this morning but there are plow berms at the end of the driveway. Not complaining 😏 Share this post Link to post Share on other sites
wallfish 20,618 #44 Posted February 24 2 hours ago, Retired Wrencher said: John I know you got more snow the we did. What was the final amount of snow did you get? It's hard to tell with all the wind and drifts but guessing about 10-14" on top of what was still on the ground from the last big one. Kind of nice NOT to have the highest totals in the area for once! 1 2 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #45 Posted February 25 21 hours ago, wallfish said: It's hard to tell with all the wind and drifts but guessing about 10-14" on top of what was still on the ground from the last big one. Kind of nice NOT to have the highest totals in the area for once! That is good for the amount. Not 2’ I sent Mike the show list for the year. I will send it to you. What is your email address? Share this post Link to post Share on other sites
cleat 9,333 #46 Posted February 25 On 2/23/2026 at 7:21 PM, wallfish said: Got all the deep stuff done but scraping with the blade had to wait until tomorrow. This is what appears to be the spring location it was on but that doesn't look right to me. Like the notch was ground in to keep it from slipping but I'm assuming it should probably be connected somewhere else. Spring hooks onto a little tab welded to the belt tension arm. Here is mine with the pulley removed. 2 1 2 Share this post Link to post Share on other sites
Sparky-(Admin) 26,359 #47 Posted February 25 2 hours ago, Retired Wrencher said: That is good for the amount. Not 2’ I sent Mike the show list for the year. I will send it to you. What is your email address? I already sent it to John Share this post Link to post Share on other sites
wallfish 20,618 #48 Posted February 25 11 hours ago, Retired Wrencher said: That is good for the amount. Not 2’ I sent Mike the show list for the year. I will send it to you. What is your email address? I got one but thanks! Hope to see you at some 1 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #49 Posted February 27 On 2/23/2026 at 12:31 PM, Sparky said: Ariens blower first and a clean up after with the 520-8…no problems. Maybe 12” and it wasn’t wet/heavy like I was expecting. Mike I am glade that storm is over with. Let’s hope this is the last one for the season. At least it is almost March. 1 Share this post Link to post Share on other sites
peter lena 10,065 #50 Posted February 27 @Retired Wrencher north stonington ct , about 15 min from me had a little over 30 inches of snow . regularly staying on the move it while you can mode , typically back cutting a snow field , and starting the movement , pete Share this post Link to post Share on other sites
