Maine Red Horse 5 #1 Posted February 22 My new to me c125 won’t stay running. When snow blowing a month ago it started to loose power and would barely throw snow. It died in the drive way and had sat for a few weeks. I then replaced the carburetor, oil, points, starter and spark plug with now success. It will start to chug very slowly and run for a few seconds with the throttle fully open and the choke half on. It then dies out and back fires about 25% of the time. With the air filter off I can see a bit of fuel sputter out the front of the carb. I feel like I’m over my head now and have hit a wall. Can anyone recommend a good mechanic in sothern Maine who would work on this for me? 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,520 #2 Posted February 22 First things first... Is it getting fuel? Check the gas cap. It needs to vent. Try starting it with cap off. Is there a fuel filter? If yes, check it for crap... I'd replace entire fuel line and put new fuel filter in. Take fuel line off carb and try starting it. Is fuel spurting out? If yes, good. If not - fuel isn't getting to carb. Could be blocked fuel line, pump, or clogged petcock valve screen. 2 1 Share this post Link to post Share on other sites
ri702bill 13,067 #3 Posted February 22 Welcome! This sounds fuel related, as in lack of fuel. Try backing off the gas tank cap. If the vent is plugged, you get that symptom.. 2 Share this post Link to post Share on other sites
ebinmaine 80,709 #4 Posted February 22 28 minutes ago, Maine Red Horse said: Can anyone recommend a good mechanic in sothern Maine who would work on this for me? Bring it Rick n Ray's in Buxton. Hands down - the best around. 5 Share this post Link to post Share on other sites
ri702bill 13,067 #5 Posted February 22 1 minute ago, SylvanLakeWH said: Take fuel line off carb and try starting it. Is fuel spurting out? If yes, good. If not - fuel isn't getting to carb. Could be blocked fuel line, pump, or clogged petcock valve screen. Fuel pump - there are two spring loaded discs inside. If one or both are not sealing, the fuel just waffles back and forth. Rare, but it happens. As mentioned, pull the line to the carb, pull he coil wire and crank it over. Fuel should spurt once each revolution.... 2 Share this post Link to post Share on other sites
Maine Red Horse 5 #6 Posted February 22 When I pull the fuel line off the carb and turn the key it pumps out plenty of fuel. 2 Share this post Link to post Share on other sites
squonk 48,126 #7 Posted February 22 When you crank it over, does it sound normal or does it sound like it's spinning a lot faster? Share this post Link to post Share on other sites
rmaynard 17,582 #8 Posted February 22 1 hour ago, Maine Red Horse said: With the air filter off I can see a bit of fuel sputter out the front of the carb. That sound to me like it is flooded. A stuck float valve will cause that. Where did you get the carburetor that you used to replaced the first one? 2 Share this post Link to post Share on other sites
953 nut 69,321 #9 Posted February 23 16 hours ago, Maine Red Horse said: I then replaced the carburetor, oil, points, starter and spark plug with now success. It will start to chug very slowly and run for a few seconds with the throttle fully open and the choke half on. When you re0place multiple parts at the same time and have poor results it is difficult to say "this is it." Start with the ignition timing, the video below will guide you through the process .Before you do the timing I would replace the condenser too 2 1 Share this post Link to post Share on other sites
peter lena 10,065 #10 Posted February 23 @Maine Red Horse regularly refer to recovering an engine stage , WITH A SEPERATE GALLON OF HEAVILY TREATED FRESH FUEL , drop carb bowl , like a fuel filter just before it , also fuel check valve , transparent fuel hose , you can see clean fuel holding up to carb , always take advantage of change , fuel hose breakdown is very common , been adding ounce or two of STA BIL , to every tank top off . have had zero fuel hose debris , for years , never leave a tank empty , always top of after use . modifications / changes I have made over the years , eliminated / stopped repetitive issues . realise this is a real challenge to many . very often simple / easy . makes me think of a rusty choke / throttle cable , sounds like a hack saw blade on threaded wire ? this is a great place to improve on / simple / easy too . you want penetrant to run out other end , also touch up any related , linkage / lever area , have also added light extension springs to my pull point / cable pull ? always pulling to close ? assists you at every setting , dare to experiment , it works , pete Share this post Link to post Share on other sites
