WHX?? 58,136 #26 Posted February 24 1 hour ago, lynnmor said: pulled the fender and gas tank every year to properly clean and oil. Share this post Link to post Share on other sites
Brockport Bill 2,478 #27 Posted February 25 9 hours ago, Ed Kennell said: Every one I bought had the cooling fins packed solid with grass. Take the seat pan, fuel tank, and supports off and clean the fins with wire brushes. Remove all the paint that is also insulating the fins and trapping heat. Then If you mow with it, blow out the fins after every mowing. i use leaf blower after every mow -- including the fins and entire rear tractor area -- important to avoid any oil or grease substance getting on fins because that becomes glue for dirt and dust to accumulate/stick - - although the grass sap can work like glue also on the tranny fins - last yr i did remove a hydro to clean and paint -- not a fun job getting between each of those fin spaces 1 Share this post Link to post Share on other sites
