FLtractor 110 #1 Posted 1 hour ago (edited) About hour from me Is someone selling this Wheelhorse 8-25. Wondering if the Briggs & Stratton 8 hp engine reliable, towing capacity if at all, such as a Rubbermaid trailer with palm frawms and or a trash can occasionally.. probably under 100lbs total trailer and contents ? Turning radius and any issues? Seller asking $200.00. thank you Edited 1 hour ago by FLtractor Share this post Link to post Share on other sites
leabassett@sbcglobal.net 170 #2 Posted 1 hour ago I had a Snapper version of that. It cut grass fine and pulled a trailer full of leaves with no problem. 1 Share this post Link to post Share on other sites
ineedanother 1,832 #3 Posted 1 hour ago The Snapper was a bit different but they're pretty cool little mowers if you have a smooth flat lawn. The Snapper I had would store standing up and turn about as close to 0* as you could get. Here's the manual for the one you're looking at. WH 8-25.pdf 1 Share this post Link to post Share on other sites
FLtractor 110 #4 Posted 46 minutes ago (edited) 38 minutes ago, leabassett@sbcglobal.net said: I had a Snapper version of that. It cut grass fine and pulled a trailer full of leaves with no problem. Thanks for the first hand experience. Would you say being 35 years old, it’s worth $200.00? Edited 44 minutes ago by FLtractor Share this post Link to post Share on other sites
FLtractor 110 #5 Posted 45 minutes ago 16 minutes ago, ineedanother said: The Snapper was a bit different but they're pretty cool little mowers if you have a smooth flat lawn. The Snapper I had would store standing up and turn about as close to 0* as you could get. Here's the manual for the one you're looking at. WH 8-25.pdf 880.99 kB · 0 downloads That’s great to know about storing. Thanks for manual link Share this post Link to post Share on other sites
ineedanother 1,832 #6 Posted 25 minutes ago One thing to note is that those are not engineered to tow anything but as noted, you likely could run a light cart around a flat yard. You would likely need to fashion a hitch though because it probably doesn't even have something to drop a hitch pin in. Share this post Link to post Share on other sites
