gwgdog66 23 #1 Posted September 30, 2009 What were the black hood years? I can make out part of the number on this one. I can make out the 21-1xx80. The engine is a K321S Spec 60424, serial number 14135580. I can date the engine as a 1984. I can't find any Info on the Toro site for an 8 Speed with a 14 HP single. Share this post Link to post Share on other sites
MikesRJ 558 #2 Posted September 30, 2009 Your machine is 1985 or later. If the engine is original then it's probably this one, as only two came with that spec. number and the other machines model is significantly different: 21-14K801 1985 Garden Tractor 314-8 8-Speed Kohler K321S-60424 Try this page, in sections B and C: http://www.mywheelhorse.com/modules.php?na...o=show_doc&id=3 And you'll probably need these: Wheel Horse Master Model List Wheel Horse Interchange-ability List - 1955-2000 Share this post Link to post Share on other sites
gwgdog66 23 #3 Posted September 30, 2009 I was thinking that may be the model number myself until I looked at the parts diagrams and the hood style was showing the newer style hood on the 314-8. I'm beginning to think this one may not have the original engine on it. :scratchead: Share this post Link to post Share on other sites
tgranthamfd 29 #4 Posted September 30, 2009 Tractor data . com is saying that from 1980 to 1984 they made the C 145 with 8 speed and automatic. 14hp Kohlers. none of the numbers fall into this catagory do they? These should be black hoods, I think. Share this post Link to post Share on other sites
MikesRJ 558 #5 Posted September 30, 2009 Are the two "XX" numbers in the model number completely obliterated, or can you make a guess at them? Share this post Link to post Share on other sites
Duff 206 #6 Posted September 30, 2009 I could be wrong, but from looking at the dash tower in the pictures, I'm fairly certain it's not a 300-series machine with a transplanted hood...... Duff :scratchead: Share this post Link to post Share on other sites
KeithB 6 #7 Posted September 30, 2009 I think the 314-8 is the lone 300 series with a 8 pinion tranny in the 8 speed Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,643 #8 Posted September 30, 2009 I agree with Duff, that is not a 300 series dash tower, but a black hood dash tower. The last black hood was 1984. Exactly where is the id plate located at? I can't remember where it was on my 1981 C-125. Here's what the dash tower would look like on a 1985: http://www.wheelhorseforum.com/index.php?showtopic=7747 Share this post Link to post Share on other sites
gwgdog66 23 #9 Posted September 30, 2009 Are the two "XX" numbers in the model number completely obliterated, or can you make a guess at them? They are not legible. Share this post Link to post Share on other sites
gwgdog66 23 #10 Posted September 30, 2009 I agree with Duff, that is not a 300 series dash tower, but a black hood dash tower. The last black hood was 1984. Exactly where is the id plate located at? I can't remember where it was on my 1981 C-125. Here's what the dash tower would look like on a 1985: http://www.wheelhorseforum.com/index.php?showtopic=7747 T-Mo that is what is leading me to believe it is an early 80's C seires with a transplanted engine. I was leaning twards an 84 C-145, but can's find any info that a C-145-8 was made in 84. The ID tage is right below the dash plate in the center. If you look at picture #2 it is the shinny area just below and to the left of the throttle knob. I'll find a soft lead pencil and some tracing paper and see if I can pull more numbers off of it that way. Share this post Link to post Share on other sites
baerpath 517 #11 Posted September 30, 2009 c145 used a shaker mount (cradle) Can't tell from the picture if it has one Duane Share this post Link to post Share on other sites
gwgdog66 23 #12 Posted October 1, 2009 c145 used a shaker mount (cradle) Can't tell from the picture if it has one Duane Duane, No shaker mount on this engine. The oil pan bolts straight to the frame. I power washed it today, and found more evidence that the engine has been worked on before. Thick black silicone on the pan gasket. I tried the pencil and tracing paper trick today, and didn't yield any more numbers. Share this post Link to post Share on other sites
tgranthamfd 29 #13 Posted October 1, 2009 I am thinking, from the depth of the seat pan, that it is definantly an 83 0r 84. From the pictures I have looked at, in the picture section, the 80', 81', and 82's all had a really deep inset of the seat. Haven't seen a picture of the 1983's, but the 1984's had a shallower seat inset. Were all of the Black hoods manufactured from 80 to 84 and were they all B or C series?? :scratchead: Share this post Link to post Share on other sites
Sparky-(Admin) 23,732 #14 Posted October 1, 2009 The C-145 8-speed was only made in 1980-81. 1980=01-14K801 1981=01-14K802 In 83-84 the C-145 was only offered as an auto. Mike.... Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,643 #15 Posted October 1, 2009 I am thinking, from the depth of the seat pan, that it is definantly an 83 0r 84. From the pictures I have looked at, in the picture section, the 80', 81', and 82's all had a really deep inset of the seat. Haven't seen a picture of the 1983's, but the 1984's had a shallower seat inset. Were all of the Black hoods manufactured from 80 to 84 and were they all B or C series?? The deep seat pans, or fender deck, that you are referring to were the plastic fender deck ones. The shallow fender decks were steel. Share this post Link to post Share on other sites
Rod(NASNUT) 1 #16 Posted October 1, 2009 Here is a pic of my 84 C-105 Share this post Link to post Share on other sites
tgranthamfd 29 #17 Posted October 2, 2009 Rod, it sure looks a lot like your machine, doesn't it. The black on the hood has been painted, it is squared off by the stering wheel where the body lines are rounded. I wonder if I can do a search with the partial model numbers and get some possible matches. :scratchead: Share this post Link to post Share on other sites
tgranthamfd 29 #18 Posted October 2, 2009 The C-145 8-speed was only made in 1980-81. 1980=01-14K801 1981=01-14K802 In 83-84 the C-145 was only offered as an auto. Mike.... Mike, that is some usefull information. Probably ruels out the c 145, then. Thanks :scratchead: Share this post Link to post Share on other sites
mcwh1950 2 #19 Posted October 7, 2009 Rod, it sure looks a lot like your machine, doesn't it. The black on the hood has been painted, it is squared off by the stering wheel where the body lines are rounded. I wonder if I can do a search with the partial model numbers and get some possible matches. 21-08K801 1985 308-8 21-08K802 1986 308-8 21-08K803 1987 308-8 21-08K804 1988 308-8 21-10K801 1985 310-8 21-10K802 1986 310-8 21-10K803 1986 310-8 21-10K804 1987 310-8 21-10K805 1988 310-8 21-10K806 1989 310-8 21-12K801 1985 312-8 21-12K802 1986 312-8 21-12K803 1986 312-8 21-12K804 1987 312-8 21-12K805 1988 312-8 21-12K806 1989 312-8 21-14k801 1985 314-8 Share this post Link to post Share on other sites
C-Series14 15 #20 Posted October 7, 2009 The ID tag may start with a 21- number but that tractor is a 1980-1984. If the 14hp engine is newer, then it doesn't make it a C-145, it could be a different 1980-1984 8-speed...C-105, C-125, C-165, etc with a different engine on it. The fender pictured was the same from 1980-1984 and of course newer. I see in my info that engine spec number as a 1985 314-8. Sounds like they put an engine and hoodstand panel from a 1985 tractor on a 1980-1984 tractor... Share this post Link to post Share on other sites
refracman 167 #21 Posted October 7, 2009 Like Mike said its a 1980-84. By it not haveing a hour meter its either a 8,10,12 hp. The engine thats on it is does denote which one it is as we know its not stock. With all the C's(exept 195&Ds) and early 3/400 made from 73 to 86 (give or take) you can put a 10hp and up tall pan kohler on them without any modifcations, everything will transfer. I have replaced a 8hp on one of these and all that is needed is the mid sixties engine mounting plate. As for the fender pan that also is not a give away. The steel pan from 85 to 07 will fit, only the holes for the hydro access are different. And because its a stick a 73-79 will fit, if the hole for the gas tank was cut out. This is the beauty of WH's, you can mix and match parts from the mid sixties on :scratchead: Share this post Link to post Share on other sites
gwgdog66 23 #22 Posted October 8, 2009 The ID tag may start with a 21- number but that tractor is a 1980-1984. If the 14hp engine is newer, then it doesn't make it a C-145, it could be a different 1980-1984 8-speed...C-105, C-125, C-165, etc with a different engine on it. The fender pictured was the same from 1980-1984 and of course newer. I see in my info that engine spec number as a 1985 314-8. Sounds like they put an engine and hoodstand panel from a 1985 tractor on a 1980-1984 tractor... Mike, The second line serial number is 0294, I seen in the post you made on the 105 that this is the build date. Terry, It's a 1980, built on or about 21 October, the engine and fender must have been replaced. Share this post Link to post Share on other sites
MikesRJ 558 #23 Posted October 8, 2009 Snow thrower choices: OLD number: Model 06-42ST04 42" Snowthrower NEW number: Model 06-48BC03 / 79350 Both require Tire Chains, Wheel Weights or Rear Weight Box (WH recommended) Share this post Link to post Share on other sites
mcwh1950 2 #24 Posted October 9, 2009 Mike, The second line serial number is 0294, I seen in the post you made on the 105 that this is the build date. Terry, It's a 1980, built on or about 21 October, the engine and fender must have been replaced. i know that the bottom set of number are supposedly be the julian date the tractor was manufactured . but how can we have a vin number that starting with a number 21 from the 1985-1989, and a julian date code of 0294 being make in oct of 1980. the starting vin should start with a 01 number and not a 21 number 01-1xx80x. help me figure this out. Share this post Link to post Share on other sites
C-Series14 15 #25 Posted October 9, 2009 Got me! Are you 100 percent sure it is 21- and not 01-? How about a pic? I guarantee it is a 1980-1984 model, but that is all I am sure of!!!! :hide: Share this post Link to post Share on other sites
