JimSraj 561 #1 Posted 23 hours ago Does anyone have any experience with the NAPA replacement ignition switch for the 111215 original. Looks like the only difference is the mounting shaft is 9/16” rather than 5/8” on the original. Both seem to be 5 pin plus ground. Thanks. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,953 #2 Posted 9 hours ago 111215 has been replaced by 103991 Both use 101884 nut so stem diameter should be the same. Share this post Link to post Share on other sites
JimSraj 561 #3 Posted 5 hours ago 3 hours ago, gwest_ca said: 111215 has been replaced by 103991 Both use 101884 nut so stem diameter should be the same. Thanks. I’ll know soon as I’m going to see what NAPA has right now. Share this post Link to post Share on other sites
JimSraj 561 #4 Posted 2 hours ago Yup, the NAPA Prime line switch works and it does have a shaft diameter of 9/16” rather than 5/8”. Comes with nut, washer and 2 keys. $32. Share this post Link to post Share on other sites
