JimSraj
Ignition switch for 1988 312-8
JimSraj
Does anyone have any experience with the NAPA replacement ignition switch for the 111215 original. Looks like the only difference is the mounting shaft is 9/16” rather than 5/8” on the original. Both seem to be 5 pin plus ground.
Thanks.
gwest_ca
111215 has been replaced by 103991
Both use 101884 nut so stem diameter should be the same.
