S416-8 397 #1 Posted Sunday at 09:41 PM So got a shock today when I went out, started the 180 and after a few min's of warming up the oil fill cap blew off with enought force to never be found again.. I haven't checked the vent house yet and with the -15 winds I get to it later just plug the fill tub and put a small trash can over it.. good thing I hope is before I got to it to shut it down the engine had no strange noises and seem to run ok.. 2 Share this post Link to post Share on other sites
lynnmor 8,471 #2 Posted Sunday at 09:47 PM 2 minutes ago, S416-8 said: So got a shock today when I went out, started the 180 and after a few min's of warming up the oil fill cap blew off with enought force to never be found again.. I haven't checked the vent house yet and with the -15 winds I get to it later just plug the fill tub and put a small trash can over it.. good thing I hope is before I got to it to shut it down the engine had no strange noises and seem to run ok.. I wonder if you have some water (condensation) in the oil that frosted up the breather and built up the pressure. Check for milk in any opening to the crankcase and milky oil. 3 Share this post Link to post Share on other sites
S416-8 397 #3 Posted Sunday at 09:49 PM (edited) thanks for the info and will do.. was wondering about the condensation because a few days ago it was raining and now it's below 0.. Now to find a new cap and dipstick Edited Sunday at 09:51 PM by S416-8 Share this post Link to post Share on other sites
953 nut 63,782 #4 Posted Monday at 01:16 PM 15 hours ago, S416-8 said: Now to find a new cap and dipstick Need to have the engine Spec Number. Then go to the Kohler parts manual for that engine to find a part number and Share this post Link to post Share on other sites
S416-8 397 #5 Posted 6 hours ago found a cap and when I get that I'll probably change the oil for a just in case and see if it all checks out Share this post Link to post Share on other sites
lynnmor 8,471 #6 Posted 4 hours ago 1 hour ago, S416-8 said: found a cap and when I get that I'll probably change the oil for a just in case and see if it all checks out When you drain the oil of course you will look for signs of water, also take a Styrofoam cup and fill it with the used oil and let it sit for awhile. Any deterioration of the cup indicates the presence of gasoline. Share this post Link to post Share on other sites
Gasaholic 346 #7 Posted 1 hour ago On 1/26/2026 at 8:16 AM, 953 nut said: Then go to the Kohler parts manual for that engine to find a part number and Always thought D-180 had an Onan Twin (B43G or B43M) D-160 had K341 Kohler, D-200 had Onan Twin B48.... But them Im an old fart my memory may not be as good as it used to be... (I do remember the D-250 with the renault water cooled engine as well..) Share this post Link to post Share on other sites
