S416-8 398 #1 Posted January 25 So got a shock today when I went out, started the 180 and after a few min's of warming up the oil fill cap blew off with enought force to never be found again.. I haven't checked the vent house yet and with the -15 winds I get to it later just plug the fill tub and put a small trash can over it.. good thing I hope is before I got to it to shut it down the engine had no strange noises and seem to run ok.. 2 Share this post Link to post Share on other sites
lynnmor 8,645 #2 Posted January 25 2 minutes ago, S416-8 said: So got a shock today when I went out, started the 180 and after a few min's of warming up the oil fill cap blew off with enought force to never be found again.. I haven't checked the vent house yet and with the -15 winds I get to it later just plug the fill tub and put a small trash can over it.. good thing I hope is before I got to it to shut it down the engine had no strange noises and seem to run ok.. I wonder if you have some water (condensation) in the oil that frosted up the breather and built up the pressure. Check for milk in any opening to the crankcase and milky oil. 3 Share this post Link to post Share on other sites
S416-8 398 #3 Posted January 25 (edited) thanks for the info and will do.. was wondering about the condensation because a few days ago it was raining and now it's below 0.. Now to find a new cap and dipstick Edited January 25 by S416-8 Share this post Link to post Share on other sites
953 nut 64,328 #4 Posted January 26 15 hours ago, S416-8 said: Now to find a new cap and dipstick Need to have the engine Spec Number. Then go to the Kohler parts manual for that engine to find a part number and Share this post Link to post Share on other sites
S416-8 398 #5 Posted January 29 found a cap and when I get that I'll probably change the oil for a just in case and see if it all checks out 1 Share this post Link to post Share on other sites
lynnmor 8,645 #6 Posted January 29 1 hour ago, S416-8 said: found a cap and when I get that I'll probably change the oil for a just in case and see if it all checks out When you drain the oil of course you will look for signs of water, also take a Styrofoam cup and fill it with the used oil and let it sit for awhile. Any deterioration of the cup indicates the presence of gasoline. Share this post Link to post Share on other sites
Gasaholic 355 #7 Posted January 29 On 1/26/2026 at 8:16 AM, 953 nut said: Then go to the Kohler parts manual for that engine to find a part number and Always thought D-180 had an Onan Twin (B43G or B43M) D-160 had K341 Kohler, D-200 had Onan Twin B48.... But them Im an old fart my memory may not be as good as it used to be... (I do remember the D-250 with the renault water cooled engine as well..) 1 Share this post Link to post Share on other sites
pfrederi 19,960 #8 Posted January 29 1 hour ago, Gasaholic said: Always thought D-180 had an Onan Twin (B43G or B43M) D-160 had K341 Kohler, D-200 had Onan Twin B48.... But them Im an old fart my memory may not be as good as it used to be... (I do remember the D-250 with the renault water cooled engine as well..) Some D160 had an Onan Twin. Others a K341 single. D180 and D200 had Cast iron Kohler Twins. K482 and K532 respectively. 1 Share this post Link to post Share on other sites
Gasaholic 355 #9 Posted January 30 17 hours ago, pfrederi said: Some D160 had an Onan Twin. Others a K341 single. D180 and D200 had Cast iron Kohler Twins. K482 and K532 respectively. OK.. Might have been regional or we just had a lot of D-160 or something.. I just remember shifting a lot of Onan engines when working on D series , typically when servicing the Sundstrand hydro pumps - usually having to replace the spline drive that bolted to flywheel , or the pump input shaft , or the control linkages or lines to and from the pump.. Mainly remember those just because it was one of the most frustrating work orders I had to deal with when working WHeel Horse (the kind that makes one cuss up a storm the whole time...) Share this post Link to post Share on other sites
pfrederi 19,960 #10 Posted January 30 4 hours ago, Gasaholic said: OK.. Might have been regional or we just had a lot of D-160 or something.. I just remember shifting a lot of Onan engines when working on D series , typically when servicing the Sundstrand hydro pumps - usually having to replace the spline drive that bolted to flywheel , or the pump input shaft , or the control linkages or lines to and from the pump.. Mainly remember those just because it was one of the most frustrating work orders I had to deal with when working WHeel Horse (the kind that makes one cuss up a storm the whole time...) D series are NOT easy to work on....The had a guy hold the hydro pump in the air and then built a tractor around it 3 Share this post Link to post Share on other sites
S416-8 398 #11 Posted February 1 Thanks and sad new.. finally got it in the garage and the left cylinder is dead. Has spark and fuel and that is it.. Now do I try to fix it, find another and use this for parts, sell it off for parts or ????? Share this post Link to post Share on other sites
lynnmor 8,645 #12 Posted February 2 8 hours ago, S416-8 said: Thanks and sad new.. finally got it in the garage and the left cylinder is dead. Has spark and fuel and that is it.. Now do I try to fix it, find another and use this for parts, sell it off for parts or ????? Check the compression first thing, if it is low pull the head to see the problem. Report back. Share this post Link to post Share on other sites
S416-8 398 #13 Posted February 2 Hi and sad news to report in that I had no compression on the left so pulled the head and 0 piston movement at all.. fear what I will find if I try to rebuild it if you can rebuild it.. maybe look for another D to use the 3-point, plow, grader and deck on Share this post Link to post Share on other sites
pfrederi 19,960 #14 Posted February 2 Quick look shows std rods 277130 for your engine K482 are available the D200 rods are hens teeth Share this post Link to post Share on other sites
lynnmor 8,645 #15 Posted February 2 4 hours ago, S416-8 said: Hi and sad news to report in that I had no compression on the left so pulled the head and 0 piston movement at all.. fear what I will find if I try to rebuild it if you can rebuild it.. maybe look for another D to use the 3-point, plow, grader and deck on Sometimes a broken rod can be replaced for a reasonable price if there is no collateral damage. I guess that you have nothing but time to lose to do the autopsy and add up the damage. Share this post Link to post Share on other sites
S416-8 398 #16 Posted February 3 Thanks and that’s my thoughts as well Share this post Link to post Share on other sites
