EB-80/8inPA 1,963 #26 Posted Sunday at 09:47 PM 15 minutes ago, sqrlgtr said: My 12hp-8 No Name is same way Tried firing up the C160 (w/ single stage blower) yesterday and no go. Gas bleeding out of the air filter housing, so I’m guessing the carb needs some attention - probably the float I suspected wasn’t quite right last time I futzed with the thing but not quite enough - after installing the electric pump. I don’t know why that would stop it from starting though. Flooded? Ran fine a couple of months ago after settling it up for winter. Any other diagnostic suggestions anybody might have would be most welcome. The B-80 plowed like a champ, though, even if the snow was piling up faster than it could be pushed out of the way. Strained a muscle working that plow index control lever a thousand times, too! Really wanted to use the blower on this, but such is life. Share this post Link to post Share on other sites
pfrederi 19,623 #27 Posted Sunday at 10:01 PM (edited) If gas is running out the carb your float valve is stuck open or the electric pump you put on is too High PSI Give the carb bowl a few sharp raps with a hammer preferably rubber/plastic. The throttle wide open no choke crank her for a while Edited Sunday at 10:03 PM by pfrederi 4 Share this post Link to post Share on other sites
John c 135 #28 Posted Sunday at 11:15 PM take some heat tape for pipes, wrap it around the engine, starter and battery, hopefully you've already got some 120v in the area for the battery charger, plug the heat tape in and the next time you need it., the battery and the engine should be warm enough to spin right over on a moments notice 3 Share this post Link to post Share on other sites
Retired Wrencher 6,353 #29 Posted yesterday at 11:25 AM 15 hours ago, wallfish said: My life is always chock full of drama! The problem is the working hours so it doesn't leave enough time for everything else. Plus the older I get, the longer it takes to get $&!t done. Seriously considering retirement. Thanks. Cables were done over the fall but that doesn't mean there can't be something. Sprayed some WD in there to try and wash it out. The oil thing might be an issue as I can't remember what I had for lunch let alone what weight oil was used when it was changed last. And yeah, that straight 30 gets thick like molasses in freezing temps so now I'm guessing it might be that John if you decide to retire, you won’t be sorry. But again you can always work part time. This will give you something to do every day for a few hours and the rest is yours to do whatever you want. 1 Share this post Link to post Share on other sites
JoeM 9,472 #30 Posted yesterday at 01:22 PM Pretty much over and it sounds like this one found some weakness. My stuff ran okay. The little 2 stroke blower needs and edge and paddles. And the old xi slows a bit when the trans gets hot, (I knew about the trans but not sure if I am going to switch out to another machine or repair) After the storm. 1 Share this post Link to post Share on other sites
wallfish 18,944 #31 Posted 22 hours ago Warming it up first worked and she fired right up. Ran through 2 tanks of gas. Some of those drifts were pretty high too. Luckily the neighbor across the street was out there with his loader and also pushed my 3ft + DOT piles to the side for me. The DOT plow piles are always the test of durability on the 2 stage's chain 2 Share this post Link to post Share on other sites
ebinmaine 76,851 #32 Posted 22 hours ago 2 minutes ago, wallfish said: Warming it up first worked Yesterday afternoon we fired up 2 tractors and the walk behind snowblower to stack them in better position. My 78/79 C121 hydro was NOT happy about being awake. Once it started I walked away for a good 15 minutes. I left the park brake on & hydro belt engaged. Definitely worth the fuel spent for the smooth running happy tractor. 2 Share this post Link to post Share on other sites
Retired Wrencher 6,353 #33 Posted 4 hours ago 17 hours ago, ebinmaine said: Yesterday afternoon we fired up 2 tractors and the walk behind snowblower to stack them in better position. My 78/79 C121 hydro was NOT happy about being awake. Once it started I walked away for a good 15 minutes. I left the park brake on & hydro belt engaged. Definitely worth the fuel spent for the smooth running happy tractor. Eric how much snow did you get? I had to use the 14 hp blower to get the huge leftover banks form the plow trucks. The blower did short work of it and three neighbors driveway entrance. At lest it was not hard packed snow. 2 Share this post Link to post Share on other sites
ebinmaine 76,851 #34 Posted 4 hours ago 8 minutes ago, Retired Wrencher said: Eric how much snow did you get? I had to use the 14 hp blower to get the huge leftover banks form the plow trucks. The blower did short work of it and three neighbors driveway entrance. At lest it was not hard packed snow. Hard to measure because of the constant light wind. I believe around 15" ? Share this post Link to post Share on other sites
Retired Wrencher 6,353 #35 Posted 4 hours ago Just now, ebinmaine said: Hard to measure because of the constant light wind. I believe around 15" ? Was it on the lite side or wet and heavy. Ours was lite. Share this post Link to post Share on other sites
ebinmaine 76,851 #36 Posted 3 hours ago 47 minutes ago, Retired Wrencher said: Was it on the lite side or wet and heavy. Ours was lite. Very light. Very fluffy. Share this post Link to post Share on other sites
rmaynard 16,814 #37 Posted 54 minutes ago On Sunday I plowed just fine with the 416-H. My driveway is only 125 feet long with a mild 1% uphill grade from garage to the road. Under most circumstances I can push snow up to 6" deep. I don't use chains. That was Sunday. When I was finished, the snow and ice wasn't. Come Monday morning there was another 2" of snow, followed by 2" of frozen mix. It was hard enough that my 240 pound didn't make a dent in it. The 416-H would not begin to push it. So I fired up the old Craftsman 24" snow blower. It slowly cut through the frozen mess. Clean up followed with the 416-H. Share this post Link to post Share on other sites
