matt monte 232 #1 Posted January 22 Can anyone advise if a transmission from a 657 would be a direct bolt in swap for my 4 speed in my b80? There is a parts 657 tractor being sold locally for cheap on MP. Before i make an offer and drag this home i figure ill ask the experts. The brief AI research of course gave me conflicting answers. Reason for swap is last snow we got i cracked the hub. Upon further inspection the woodruff keyway was wallowed out causing damage to axle. I might eventually repair the transmission but its very low on the things to do list. The B80 is a 3rd string backup to my 312-8 & 308-8. If it does, great ill make an offer, if not ill wait for something local to pop up. I dont mind some fabrication but didn't feel like getting involved in hub removal right now, done it a few times, always an unpleasant experience. Thanks in advance for any input regarding. Share this post Link to post Share on other sites
ri702bill 11,521 #2 Posted January 22 You have an early B80 with a 4 speed. Yes the 657 4 speed should bolt right in. Other options include going with a Raider 6 speed (easy swap with some mods) or an 8 speed like in your 300 series (a bit more work) My... 1 Share this post Link to post Share on other sites
ebinmaine 77,763 #3 Posted January 22 657 has a 3-speed. That is NOT a direct swap for your mid-70s tractor. You have a 4 speed. The brake drum is in a different location and the brake linkage pulls from a different direction. 2 1 Share this post Link to post Share on other sites
ri702bill 11,521 #4 Posted January 22 I stand corrected. But, if the 657 is complete & runs, why not?? 1 Share this post Link to post Share on other sites
ebinmaine 77,763 #5 Posted January 22 Just now, ri702bill said: I stand corrected. But, if the 657 is complete & runs, why not?? You can make it work but only with one pedal. The B and C Series from 1974 up had two pedals. To put an early transmission into a later tractor you are far better off to swap over the entire transmission tunnel so the linkage is all there and correct. Having tried this a couple times I'll very likely never do it again. To get a two pedal tractor back up and running again your best bet is to wait for a correct four-speed or any of the eight speeds. 2 Share this post Link to post Share on other sites
matt monte 232 #6 Posted January 22 its appears complete with some aftermarket honda engine attached, no clue if that runs. However i could just swap my kolher 8hp over to the 657 and use that which would be easier to do then swapping trans, no? I agree i wouldnt swap trans only to not have correct linkage ready for brake etc. Its on MP in NJ no clue how to link ad to this thread. I appreciate all the feedback 2 Share this post Link to post Share on other sites
ebinmaine 77,763 #7 Posted January 22 19 minutes ago, matt monte said: its appears complete with some aftermarket honda engine attached, no clue if that runs. However i could just swap my kolher 8hp over to the 657 and use that which would be easier to do then swapping trans, no? I agree i wouldnt swap trans only to not have correct linkage ready for brake etc. Its on MP in NJ no clue how to link ad to this thread. I appreciate all the feedback Links to ads aren't allowed. Without knowing the condition of the rest of the tractor it's tough to say but you'll obviously have to change the engine, all wiring. Ignition coil and switch. One thing to keep in mind is that a 657 only has one pedal and if you're accustomed to that, it's fine. All of Trina's tractors are single pedal rigs and I refuse to drive them more than just a few feet. I like a separate brake pedal. You have to go THROUGH the clutch part to get to the brake part. Share this post Link to post Share on other sites
ri702bill 11,521 #8 Posted January 22 35 minutes ago, ebinmaine said: You have to go THROUGH the clutch part to get to the brake part. And you call yourself a Truck Driver !!! Yes, it is a different animal, jumping off the 854 and onto the C81... Share this post Link to post Share on other sites
ebinmaine 77,763 #9 Posted January 22 13 minutes ago, ri702bill said: And you call yourself a Truck Driver Every truck I've ever driven and every fork lift I've ever operated has had a separation of clutch and brake.... except the increasingly rare AUTOMATED manual transmission trucks. Note the difference in spelling. No clutch pedal. 😕 But you don't drive it like a true manual transmission in the construction industry. Now most of both machines are automatics. 1 1 Share this post Link to post Share on other sites
ri702bill 11,521 #10 Posted January 22 2 hours ago, ebinmaine said: Now most of both machines are automatics. And the art of double-clutching fades as a distant memory... 1 1 Share this post Link to post Share on other sites
ebinmaine 77,763 #11 Posted January 22 1 hour ago, ri702bill said: And the art of double-clutching fades as a distant memory... Believe it or not that's been fading FAR longer than most folks realize. The first heavy truck I drove was a 1999 IHC with a VERY tough clutch. I taught myself to double clutch on that and immediately taught myself how to shift WITHOUT the clutch. Haven't used one since, other than at stop signs and lights. All the drivers I've known. All the 150 plus trucks I've driven. All the people I've trained. ONE guy double clutched every shift. One. 2 Share this post Link to post Share on other sites
sqrlgtr 2,300 #12 Posted January 23 1 hour ago, ebinmaine said: Believe it or not that's been fading FAR longer than most folks realize. The first heavy truck I drove was a 1999 IHC with a VERY tough clutch. I taught myself to double clutch on that and immediately taught myself how to shift WITHOUT the clutch. Haven't used one since, other than at stop signs and lights. All the drivers I've known. All the 150 plus trucks I've driven. All the people I've trained. ONE guy double clutched every shift. One. Agree 100% I can double clutch or I should say I used to could but its been a while so might take a mile or two. I never understood why people insisted on double shifting clutch when you can shift without using clutch at all, up or down when you get used to your truck 2 1 Share this post Link to post Share on other sites
Treepep 1,085 #13 Posted January 23 13 hours ago, ebinmaine said: Believe it or not that's been fading FAR longer than most folks realize. The first heavy truck I drove was a 1999 IHC with a VERY tough clutch. I taught myself to double clutch on that and immediately taught myself how to shift WITHOUT the clutch. Haven't used one since, other than at stop signs and lights. All the drivers I've known. All the 150 plus trucks I've driven. All the people I've trained. ONE guy double clutched every shift. One. Hands down my favorite vehicle was my 1963 F7 dump truck. Fire engine red. I bought it from a corn farmer. Grain truck with 17000 original miles. Needed the normal biz to be reliable. High/low 4 speed including reverse. Best bet was to double clutch or not clutch at all. BIG tow hooks in the front. Low/reverse you could pull a building down. Double stomp works best on earlier rigs. I drove a model T ONCE. Having driven trick cars most of my youth the experienced gentleman that allowed me to drive his restored rig was impressed. Facts are.. nearly everything is fairly intuitive. Not a rocket surgeon, never will be. Pay attention and if you cannot... ask square folks 1 2 Share this post Link to post Share on other sites
ri702bill 11,521 #14 Posted January 23 Yup - it's all about matching the engine RPM to the ground speed and the feel of the shifter. Clutch optional... 1 Share this post Link to post Share on other sites
