rmaynard 16,902 #1 Posted January 21 I spent the better part of the day removing and cleaning my gas tank, replacing the fuel lines, and installing the 1-3 psi electric fuel pump on the 416-H. All went well until the first test run. Engine started, but it went to full throttle with throttle lever set a idle. I had to stop and move on to another project. Having not touched anything other than the fuel delivery system, I somehow must have done something to the throttle, but I can't look at it again until 10 PM tonight. As Roseanne Roseannadana said, "it's always something". 2 Share this post Link to post Share on other sites
sqrlgtr 2,247 #2 Posted January 21 1 hour ago, rmaynard said: I spent the better part of the day removing and cleaning my gas tank, replacing the fuel lines, and installing the 1-3 psi electric fuel pump on the 416-H. All went well until the first test run. Engine started, but it went to full throttle with throttle lever set a idle. I had to stop and move on to another project. Having not touched anything other than the fuel delivery system, I somehow must have done something to the throttle, but I can't look at it again until 10 PM tonight. As Roseanne Roseannadana said, "it's always something". Sounds like governor going wide open they will do that if you forget or don't hook throttle cable back up. I've done it more than once . 2 Share this post Link to post Share on other sites
rmaynard 16,902 #3 Posted January 22 2 hours ago, sqrlgtr said: Sounds like governor going wide open they will do that if you forget or don't hook throttle cable back up. I've done it more than once . Yup, just took the air cleaner base off and found that I had somehow wedged the throttle linkage wide open. Oops. All fixed. 9 Share this post Link to post Share on other sites
My_horse 87 #4 Posted January 23 Ordered a new mechanical fuel pump for my 314-8 today, and filters and new fuel line. seem to be getting only a small amount of fuel in the filter, and long cold cranking times to get it started. It’s 26 years old with original pump and lines. Not always fed ethanol free, until a few years ago. It’s probably time. 3 Share this post Link to post Share on other sites
RED-Z06 2,718 #5 Posted January 23 I put an electric pump on my deere 420 and it makes my headlights flicker, works fine, starts fine...just flashing headlights 1 Share this post Link to post Share on other sites
Retired Wrencher 6,480 #6 Posted January 23 On 1/21/2026 at 8:00 PM, rmaynard said: Yup, just took the air cleaner base off and found that I had somehow wedged the throttle linkage wide open. Oops. All fixed. Bob glade you found the problem. Looks like winter is here now for some of us. It’s always good to be ready. Not looking forward to possible 1 foot or more of snow coming our way. Well that’s winter. 1 Share this post Link to post Share on other sites
rmaynard 16,902 #7 Posted January 23 36 minutes ago, Retired Wrencher said: Not looking forward to possible 1 foot or more of snow coming our way. Well that’s winter. Nor am I 2 Share this post Link to post Share on other sites
Retired Wrencher 6,480 #8 Posted January 24 (edited) 23 hours ago, rmaynard said: Nor am I Well at least Bob we have good tractors to help and some snow blowers to finish up the job. But lately I have been doing the opposite way. I find it easier to blow first then plow cause ,my wife had both her knees done and she wants it down to it the pavement. Can’t blame her. Stay safe. Edited January 24 by Retired Wrencher 2 Share this post Link to post Share on other sites
