702854boy
Cub Cadet 122
ri702bill
That broken LF spindle looks awfully busy. It is the Master side, the RF is moved by it thru the tierod. Is the LF a 3-piece assembly - lower, shaft and upper or are the lower and shaft 2 parts welded into one?? Looks repairable if you cannot find a good used one.
702854boy
The top part that the steering box hooks up to is roll pinned onto the spindle but the part that goes through the axle and the part on the wheel is supposed to be one piece and from the looks of it, its going to be a pain in the butt to weld if we have to because the bottom part needs to be flat since it goes right against the axle.
PWL216
@702854boy I have a CC 122. If there are pics you need I can send them along. Mine is a 1966 but I assume they are similar.
702854boy
@PWL216, do you know how to get the steering wheel shaft out of the steering box? as my steering wheel is stuck on it and already cracked from age and I don't want to break it.
702854boy
Progress so far for today
702854boy
Well with some observing how everything went together I was able to loosen the part that goes through the steering box and connects to the wheels and take the bottom cap of the steering box off and hammer on the metal part that went through the steering wheel and the shift popped right out. It is most likely going back together with a nice coating of the silver cancer. I also noticed that there is a chip missing out of the head so now I need a k301 head. After I got the steering wheel out of the way I was able to take the hood stand off so that I can redo the wiring and weld up the fatigue cracks when I get to that point.
702854boy
Here's the photos of the progress so far
702854boy
Would the head off of a 14 horse Kohler work on the 12 horse?
Gasaholic
Yep. as far as parts go, K301 and K321 are identical in all respects except bore size (piston & rings)
702854boy
Got the steering box torn apart and degreased and realized that one of the bearing things in it exploded so if anyone knows where to get a bearing thing like shown in one of the pictures below that be helpful. I also took the head off of a froze up 14 horse engine that we have laying around and shot some kroil in the bore to see if I cant get it freed up in the future. Edit: I'll post the photos later when I can use my Chromebook as my phone isn't allowing me to post photos right now.
Edited by 702854boy
702854boy
This  is the type of bearing i need20260114_164154.jpg.83d40a96b1f8e9bdb8e348012ceba0cb.jpg
oliver2-44
I rebuilt a similar steering box on a 1965 case. On the Case forums I was told I didn’t have to have the plastic spacer that hold the balls.  Just go to ace and get any missing balls. Arrange them on the race with heavy grease to hold them. It’s a little harder to reassemble without the plastic piece, but it’s doable. My Case is just a show tractor but it has worked for several years without the plastic spacer.
702854boy
@PWL216, would you be able to post some pictures of all of the wire clips/brackets that hook up to the engine and around there, my monkey brain forgot to take photos before tearing apart.
702854boy
Would anyone happen to know how much gear oil the tranny holds?
Easton Rich
Google tells me 7 pints? :eusa-think:
