kpinnc 19,107 #26 Posted February 13 (edited) 1 hour ago, WHX?? said: A vital piece if you want to put a deck on. Another option is to get a new Tach-a-matic belly hitch and run newer decks. Factory holes are already in the frame. Fabbing a front hitch for the mule drive is easy. Also has holes in the frame. All you need are a couple pieces of flat bar and a front hitch from a newer (1974 and up) machine. I had to cut the one on my Bronco in the pic below to get around the hood stops but you won't have to on a 1257. Edited February 13 by kpinnc 1 1 Share this post Link to post Share on other sites
Retired Wrencher 7,043 #27 Posted February 13 (edited) On 1/10/2026 at 6:30 PM, WHX?? said: No not really rare Junior but a huge bonus if in decent shape. With only two of those long spokes they broke from weight when mounting and dismounting. They were then discontinued and replaced by the very common one on '68 Raiders and just about everything until the "soft touch" ones came out. I I'll second ... This the tractor you need the SG light for? I third that. Edited February 13 by Retired Wrencher 1 1 Share this post Link to post Share on other sites
Retired Wrencher 7,043 #28 Posted February 13 (edited) 11 hours ago, TonyToro Jr. said: Finally got the new heater installed in the garage so now it’s comfortable to work in there. Got the belt guard painted that I got from @Easton Rich probably 2 weeks ago and it’s just been sitting inside. Today we turned the heater on and brought the tractor inside. Mounted up the belt guard and installed the fuel tank I decided to use. And finished up routing the fuel line and installed shut off and filter. Too dark to see of it drives so the maiden voyage will be tommorow. Also, in the last picture there is a weird little round piece that went on the foot peg. I’m thinking it’s for a mower deck? I took it off as I have no use for it. Tony in that third pick you should have two 6 Gage wires from the switch to the generator and one from the battery to the switch. Also a heavey wire to the ground to the battery. They need heavy wire to correctly operate. But once it is done you will be happy. Edited February 13 by Retired Wrencher Ok 1 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,560 #29 Posted February 13 14 hours ago, WHX?? said: Yes it's for hanging the rear of the deck mule drive off of. I would encourage you to leave it on to avoid losing it. A vital piece if you want to put a deck on. Any luck with the SG light? Just so you know the original gas tanks are pretty available if you want to go that route. Ok thanks for the info. Havent put the light on yet as I’m just trying to get it driving now. For the gas tank I decided to just use a snowblower take since we have a lot of them and they are plastic so it won’t rot out. 2 Share this post Link to post Share on other sites
TonyToro Jr. 2,560 #30 Posted February 14 (edited) It went on its voyage! It hasn’t been started in a month and I barely even bumped the key and it fired right up. It shifts through all the gears nicely and drives smooth. But I was coming back up the driveway and it was like the choke turned on. Made it back up and leaking gas from the front of the carb. Needs a carb rebuild. Also I need throttle cable so I will be posting a wanted add for that. Sorry no pictures or videos. Edited February 14 by TonyToro Jr. 1 Share this post Link to post Share on other sites
Easton Rich 1,294 #31 Posted February 14 You sure made that belt guard look good! Share this post Link to post Share on other sites
WHX?? 58,388 #32 Posted February 14 44 minutes ago, TonyToro Jr. said: Also I need throttle cable so I will be posting a wanted add No need to [post a ad .... https://www.ebay.com/itm/135550277039 2 Share this post Link to post Share on other sites
TonyToro Jr. 2,560 #33 Posted February 14 39 minutes ago, Easton Rich said: You sure made that belt guard look good! Thank you. Tried my best! 2 Share this post Link to post Share on other sites
TonyToro Jr. 2,560 #34 Posted February 14 33 minutes ago, WHX?? said: No need to [post a ad .... https://www.ebay.com/itm/135550277039 Perfect thank you! Share this post Link to post Share on other sites
TonyToro Jr. 2,560 #35 Posted February 16 On 1/12/2026 at 6:03 AM, Retired Wrencher said: Tony I have a fender and the seat pan so you could have Matt make up a seat for that would be original to that tractor like this one. let me know if you’re interested. I might take you up on that. I am not sure if we have any of those seat pans in stock but I will definitely let you know. Thank you. 2 Share this post Link to post Share on other sites
Retired Wrencher 7,043 #36 Posted February 16 On 2/13/2026 at 8:31 PM, TonyToro Jr. said: Perfect thank you! Tony if you have the original keep it to make sure it is the same length.I bought a choke cable it is a little short. So check iteam details. 1 Share this post Link to post Share on other sites
WHX?? 58,388 #37 Posted February 16 13 hours ago, TonyToro Jr. said: seat pans in stock You know you are a true horse head when you have things "in stock" ... 3 Share this post Link to post Share on other sites
Easton Rich 1,294 #38 Posted February 16 Ive got one of those seat pans if you want it. I could ship it with your axle if you wanted. I'd just take shipping for it 2 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,560 #39 Posted April 7 So this past weekend finally got around to working on this tractor again. Installed new throttle cable, and the carb kit. Also replaced the screws that hood on the air filter assembly. And we are now running beautifully! But wait. This tractor still isn’t finished yet. I have the starter gen light I got from @WHX?? and some new shoes to put on it! IMG_1904.mov 6 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,898 #40 Posted April 8 I love the sound, or lack of, when a start/gen tractor is started up! Thanks for the video 5 Share this post Link to post Share on other sites
Retired Wrencher 7,043 #41 Posted April 8 (edited) Tony Make sure your ideal is around 1200 rpms. I sound a little low to me. If you can get one of these. It is a RPM meter. Very handy. Also if you ever want to sell it i hope you send me a message. Cash in hand. Edited April 8 by Retired Wrencher 1 Share this post Link to post Share on other sites
Retired Wrencher 7,043 #42 Posted April 9 On 4/7/2026 at 8:28 PM, Sparky said: I love the sound, or lack of, when a start/gen tractor is started up! Thanks for the video 100% agree to that Mike. Share this post Link to post Share on other sites
Retired Wrencher 7,043 #43 Posted April 12 On 1/10/2026 at 5:02 PM, TonyToro Jr. said: Yes it does. Is that rare? Tony I do not think there that rare but not plentiful either. Now I would say the 1267 would more rare because of the six speed. Still liking what you have. Share this post Link to post Share on other sites
