tvr383 0 #1 Posted September 29, 2009 I know that a coil can be permanently dammaged if the ignition switch is left in ON or RUN position while engine is not functionning. It happened to me recently..and I believe it could happen to many of us specially in a period of setting up an engine..the engine dies and we forget cutting ignition off! So I'm installing a new coil on my K-582 twin engine and wonder if there is not a kind of circuit breaker that could be installed on the wire (positive) to the coil!? I could install a small warning light that would be on while the switc is on but still it could be disregard (wife and younger kids are to use it!). Any suggestions? thanks. Share this post Link to post Share on other sites
Save Old Iron 1,568 #2 Posted September 29, 2009 showing my ignorance here - is this coil energized off a mechanical points system or electronic trigger ? Share this post Link to post Share on other sites
tvr383 0 #3 Posted September 29, 2009 showing my ignorance here - is this coil energized off a mechanical points system or electronic trigger ? This has mechanical driven points system and condenser. This system has mechanical driven points and condenser..its a K-582 twin Kohler. Share this post Link to post Share on other sites
Save Old Iron 1,568 #4 Posted September 29, 2009 tvr383 you may want to Google "watchdog timer circuit" this is a little "out there" but this electronic circuit watches for a continuous train of pulses (points closing and opening) - if the pulses stop appearing at its input for longer than a specified period (say a few seconds) - then the watchdog circuit wakes up and sends a signal out to what could be a buzzer or a light to alert you. Bad news is you will have to construct one - good news is that with even a minimum amount of electronics savvy, its easy. The input could be to watch for the 0 to 12 volt transitions at the negative terminal of the coil - once the transitions stop - and a preset time goes by - the alarm will go off. again, its a little out there but possible. Share this post Link to post Share on other sites
oldandred 15 #5 Posted September 29, 2009 yea put a timer on it and as soon as you get to cutting grass the engine cuts off thats a gread idea BUT not for me just cut the switch off or put a light on the ing side when on to remind like a yellow or green light Share this post Link to post Share on other sites
Save Old Iron 1,568 #6 Posted September 30, 2009 Google " watchdog timer" or " missing pulse detector" to get a better understanding of what these do - they are not egg timers although there's another idea ......... egg timer the only problem is forgetting to look at the light after you forget to turn off the switch its tough getting old !! :scratchead: Share this post Link to post Share on other sites
Save Old Iron 1,568 #7 Posted September 30, 2009 tvr383, just another thought - what actually destroys the coil is probably heat - so lets measure heat there are many thermostats the size of a dime that could be strapped to the ignition coil - you would have to find a temp range somewhat but not too far above the normal operating temperature of the coil and insert this thermostat in series with the positive or negative side of the coil wire - when the coil heats up past the therm stat trip point - power is removed from the coil same idea as some of the hydro overtemp alarms http://www.allelectronics.com/make-a-store...REAKER/-/1.html of course you would have to obtain the proper temp range by contacting the switch manufacturer after testing your coil under actual operating conditions. Share this post Link to post Share on other sites
tvr383 0 #8 Posted September 30, 2009 tvr383, just another thought - what actually destroys the coil is probably heat - so lets measure heat there are many thermostats the size of a dime that could be strapped to the ignition coil - you would have to find a temp range somewhat but not too far above the normal operating temperature of the coil and insert this thermostat in series with the positive or negative side of the coil wire - when the coil heats up past the therm stat trip point - power is removed from the coil same idea as some of the hydro overtemp alarms http://www.allelectronics.com/make-a-store...REAKER/-/1.html of course you would have to obtain the proper temp range by contacting the switch manufacturer after testing your coil under actual operating conditions. thanks for the ifferent options offered.The mini temp. sensor has to be put aside as it gets (as hot as the oil's own temp I gess) hot in thisarea from thw nearby twin mufflers..23 hp engine here! The small electronic appliances based on the points cycling sounds interesting but as said I'll need to find it if it does exist!? The warning light offers some easyer installation for sure...I'll see. Ron. Share this post Link to post Share on other sites
Save Old Iron 1,568 #9 Posted September 30, 2009 here is one good example input would be from the points - it recieves pulses as long as the engine is running output could be to a light or buzzer - the output would stay high(+12v) until the input stops receiving pulses the circuit then forces the output low - grounding the buzzer or light all the parts are available at your local radio shack and the total $$ cost here is less than $5.00 - again, the downside is you either have to construct it yourself or have someone fab it up for you - probably an hour or two on the workbench :scratchead: Share this post Link to post Share on other sites
tvr383 0 #10 Posted October 1, 2009 here is one good example input would be from the points - it recieves pulses as long as the engine is running output could be to a light or buzzer - the output would stay high(+12v) until the input stops receiving pulses the circuit then forces the output low - grounding the buzzer or light all the parts are available at your local radio shack and the total $$ cost here is less than $5.00 - again, the downside is you either have to construct it yourself or have someone fab it up for you - probably an hour or two on the workbench Thanks Old Iron..I will print this a refer it to someone who knows electronics. Share this post Link to post Share on other sites
linen beige 15 #11 Posted October 1, 2009 If not already so equipped, put a safety switch under the seat that cuts the power to the coil when the seat is not occupied. That way even if you leave the switch on and go to the house the safety switch will still cut the power to the coil. Share this post Link to post Share on other sites
Save Old Iron 1,568 #12 Posted October 1, 2009 Absolutely the best and most elegant suggestion there is for this issue - as long as the switch cuts off the ignition power and not just locks out the starter bypass relay - and as long as the tractor he has actually has seat safety switches - but from reading most of the posts regarding troubleshooting - everyone hurries to rip them out and bury them in the scrap pile - never to be seen again. I did not want to offend anyone by suggesting they put them back into operation I still think we do a dis-service to any new members who are reading our posts in which which actively discourage the use of safety devices, Temporary bypass for troubleshooting - no problem - never enable them again - I'll stick my neck out here and say I have five tractors - ALL THE SAFETY DEVICES WORK ON THEM. If they break, I'll personally spend the $5.00 and some quality time with my grandson to fix them. Share this post Link to post Share on other sites
tvr383 0 #13 Posted October 1, 2009 If not already so equipped, put a safety switch under the seat that cuts the power to the coil when the seat is not occupied. That way even if you leave the switch on and go to the house the safety switch will still cut the power to the coil. None of that on my tractor actually,,not sure if it ever had one being a 1973 model...but for a safe usage of it ,specially while mowing,it would be an excellent device to have and its double function to protect the coil sounds simplyier to me poor ignorant in electronics! My craftsman 4000 has one similar device,that shutt off the engine if the electric PTO is ON...the only drawback is when my lightweight 10 years son try to put the brake on he lifts himself from the seat and there goes on the device..no big deal! Any suggestions as where can be bought one similar switch at reasonnable price? I will check Craftsman . Thanks again, Ronald. Share this post Link to post Share on other sites
