sqrlgtr
Battery/Starter Crimp Tool
sqrlgtr
Looking to get a crimper for making battery and starter cables. Mainly for 8 ,6, and 4 Gauge wire/lugs. I hate not being able to find the correct length and or wrong size lug cables :angry-banghead:. I think I would rather have the "plier" type but not ashamed to use a hammer :handgestures-thumbupright:. What y'all recommend?
ebinmaine
I bought the hammer type specifically because the copper lugs I am using for the ends are heavy duty. I have better than average grip strength and could have gone with the flyer type just as easily I guess.
Couple things to note on the hammer type.
It's designed to be bolted down and I choose not to do that so I have to be prepared for it to jump back up every time I hit it.
If you choose to go the hammer type and if you choose to bolt it down, be very selective about where you put it. My experience shows me that you definitely want to mount it on top of a workbench post. I personally, use it on the concrete floor only.
  • Excellent 2
Handy Don
I’m not opposed to either the pincer or hammer style, but I’ve gone to the soldered on style of lug for the relatively few times I need to make new heavy cables.
And, by the way, keep an eye out at tag and garage sales for jumper cables. A good set (heavy, flexible, stranded copper wire) can yield some great battery/starter cables.
Edited by Handy Don
  • Like 7
Mike'sHorseBarn
I'm gonna follow along on this because I've been wanting to get a battery cable setup for a long time and just never pulled the trigger. :coffee:
ri702bill
My Son & I have had good success using the HFT hand held Hydraulic Lug Crimper. Just remember to put the shrink tubing on first!!
gwest_ca
I open up a flaring bar and lay the terminal in the appropriate slot. Hit the terminal with a blunt chisel and hammer.
Achto
At work I use a hydraulic crimper.
For at home I bought a set of these and used a grinder to round off the cutting edge. Works great & low price. :thumbs2:
https://www.menards.com/main/hardware/fasteners-connectors/fastener-accessories/tool-shop-reg-nut-splitter-2-piece/ts-dg-2ns/p-1642874299975476-c-19360.htm
Edited by Achto
  • Like 5
ebinmaine
Just as a point of information for those reading this thread. The way you stated that sentence is actually very important.
As a general rule it is not recommended to use solder on a joint that will experience vibration.
Because of your limited use and relative decent usage area I don't see it being an issue for you.
With our tractors being used on our rough twisted uneven terrain I would not use a soldered connection.
  • Like 5
sqrlgtr
Thanks for all the input and suggestions. Looking hard at the HFT hydraulic unit with a couple coupons I think it will be pretty competitively priced with the pincher type. The hammer type would probably be cheapest and work just as well. Got to make a trip to Dr today and HFT is just up road from Hospital so will try and check out there hydraulic unit this evening.:D
Handy Don
Hmmm. Have you seen the method that uses a plug of solder melted Into a closed-end terminator lug? The next to last step is to mechanically crimp it (I use a bench vise). Then the shrink tube.
The solder eliminates any chance of moisture or other contamination becoming trapped inside the connector, provides outstanding electrical contact, and cushions the wire strands for the crimp step.
ebinmaine
I like this idea. And I used to do it for that reason.
I stopped because I had one or two connections go bad but I don't recall how...
Then I got reading on the interwebs and discovered that a lot of people that use machines in a high vibration environment do not recommend the soldering because it causes the connection to be too strong IN the solder and more brittle right at the edge.
Combine that with changes in heat that some solders need to melt and there can be tempering issues.
sqrlgtr
Pulled the trigger on this one from HFT. Was surprised how many dies came with it. Crimps 14 to 0 gauge :handgestures-thumbupright: Will be proud to be able to make my own cables. I hate haveing extra long cabels and to big ol lug holes when not needed and has to be easier on electrical systems.
  • Excellent 3
Handy Don
Yes, I can definitely see how wire in a cable allowed to vibrate at a soldered connection could become brittle with repeated cable flexes. I guess I’ve had no issues because of my routing which moves the flex away from the terminator and the multiple layers of shrink tube that stiffen the point where the cable enters the terminator.
Edited by Handy Don
  • Excellent 2
WHX??
Ahhh the nut cracker suit... :laughing-rolling:
I just always ground off that lilttle flare &  soldered & shrink with no issues so far. If I need a nice set for a cherry resto I just put in a job order at Dan's work. :lol:
:text-yeahthat:Trolling motor wire works good too... very flexible.
They say many small conductors carry current better as the electron flow is greatest on the perimeter of the conductor.
  • Excellent 2
sqrlgtr
Good to have friends in low places :ychain:
  • Haha 1
wallfish
I ground just the tips of my bolt cutter for crimping those lugs. The tip of the cutting edges are never really used for cutting anything anyway so now it's a dual use tool. :twocents-02cents:
WHX??
:text-yeahthat:and this is why the eyecrometer comes out with the BFH... ;)
  • Haha 3
ineedanother
I did the same, and with the "Pittsburgh" cable cutters as well. My next step will be to fashion some sort of clamp for my vise or something so it can be stationary. It's a bit unwieldy when just hand-held managing the cable and lug.
  • Excellent 2
sqrlgtr
Hadn't thought about that, I havent had a chance to try it out yet. I figured it couldn't be any more cumbersome than the plier type. Maybe mount it to a block of wood first then put it in vise :confusion-shrug:, probably use a set of soft jaws in vise and hold it by the lower handle, just thinking out loud here? I will find out in a day or two :D.
WHX??
Woulda thought it woulda been three times this...
sqrlgtr
yeah me too, throw in a coupon are two gets down there pretty sensible. 16000psi of pure crimping fury.:D
Edited by sqrlgtr
EB-80/8inPA
7 hours ago, Bar Nuthin said:
Santa Claus dropped this set off for me, but I haven't had a chance to use it yet
That’s the exact same set I got off the jungle site.  No complaints.  But I do regret not buying a bucket full of cables selling dirt cheap when a local old timey sole proprietor went out of business.  Copper cable has become ludicrously expensive.
Absolutely!  Or scavenge the bone yard for battery cables to cut to size, but I bet those are up in price, too.
  • Sad 1
