CD Long Jr 203 #1 Posted January 7 (edited) I worked in the oil patch & refineries my entire career. When I started trying to take it apart, that little guy inside said you're peein' in the wind. When I had Liquid Wrench comin' out the bottom of the nut and it wasn't turnin' I KNEW I was in trouble. Two 18inch pipe wrenches and a 4lb hammer later, it's apart. Threads in nut are flat. Useless, but it's apart. I listened to you guys and feel good! Edited January 7 by CD Long Jr 6 1 Share this post Link to post Share on other sites
Wishin4a416 2,610 #2 Posted January 7 Wow! That was stuck. Maybe a member can fix you up with some used pieces to get you going. 4 Share this post Link to post Share on other sites
ebinmaine 81,282 #3 Posted January 7 If you need a replacement I can see what we have... 2 1 1 Share this post Link to post Share on other sites
peter lena 10,125 #4 Posted January 7 @ C D LONG JR , got a parts hint on that mule drive ? that thread assembly should be fairly easy to replace , done a number of them , the belt pulleys , as just posted by @ ebinmaine he might be able to help you out , was going to emphasize the careful cleanout of related belt pulleys , take a picture of original of placement , and washers , shure he will set you up correctly , good luck , pete 3 Share this post Link to post Share on other sites
CD Long Jr 203 #5 Posted January 7 (edited) 1 hour ago, Wishin4a416 said: Wow! That was stuck. Maybe a member can fix you up with some used pieces to get you going. That would be great, but I won't need it until I get a snowblower. I have a front blade. The deck is shot. I got her just for snow removal, but readin' a lot of post on here, they are one he?? of a tractor. Edited January 7 by CD Long Jr 2 Share this post Link to post Share on other sites
ebinmaine 81,282 #6 Posted January 7 2 minutes ago, CD Long Jr said: That would be great, but I won't need it until I get a snowblower. The deck is shot. I got her just for snow removal, but readin' a lot of post on here, they are one he?? of a tractor. Check out the video I just posted on What have you done to your Wheelhorse today 1 Share this post Link to post Share on other sites
CD Long Jr 203 #7 Posted January 7 1 hour ago, peter lena said: @ C D LONG JR , got a parts hint on that mule drive ? that thread assembly should be fairly easy to replace , done a number of them , the belt pulleys , as just posted by @ ebinmaine he might be able to help you out , was going to emphasize the careful cleanout of related belt pulleys , take a picture of original of placement , and washers , shure he will set you up correctly , good luck , pete Pete, is there a Cold roll pin that holds the knob on? I need to get it out of the mule bracket without tearing anything else up. Share this post Link to post Share on other sites
lynnmor 9,081 #8 Posted January 7 29 minutes ago, CD Long Jr said: That would be great, but I won't need it until I get a snowblower. I have a front blade. The deck is shot. I got her just for snow removal, but readin' a lot of post on here, they are one he?? of a tractor. Maybe I missed something, the mule drive goes with the mower deck and not needed for a snowblower. 2 1 Share this post Link to post Share on other sites
peter lena 10,125 #9 Posted January 7 @CD Long Jr best thing for that pin is a penetrant soakage , and a size to size solid round punch , basically , no bouncing , will give that pin the solid impact , you need to move it , been there done that , also on the snowblower and mower deck , they are both driven by the same mule drive . with a little , functional detailing , basically bearing lube change out , it works with ease, done a number of those , pete 1 Share this post Link to post Share on other sites
Ed Kennell 47,946 #10 Posted January 8 6 hours ago, lynnmor said: Maybe I missed something, the mule drive goes with the mower deck and not needed for a snowblower. Good point Lynn. Those old junk mule drives do make great front weight brackets, plow sway stabilizers, and reciever mounts. 2 Share this post Link to post Share on other sites
CD Long Jr 203 #11 Posted January 8 9 hours ago, lynnmor said: Maybe I missed something, the mule drive goes with the mower deck and not needed for a snowblower. I haven't researched the snowblower yet. Is it direct drive from the PTO? 1 Share this post Link to post Share on other sites
CD Long Jr 203 #12 Posted January 8 (edited) 8 minutes ago, CD Long Jr said: I haven't researched the snowblower yet. Is it direct drive from the PTO? I got the answer. Direct drive from the PTO. Did some homework. Edited January 8 by CD Long Jr 1 Share this post Link to post Share on other sites
Ed Kennell 47,946 #13 Posted January 8 2 hours ago, CD Long Jr said: I haven't researched the snowblower yet. Is it direct drive from the PTO? Yes, the blowers have thier own spring loaded belt tensioning pulleys. 2 Share this post Link to post Share on other sites
