JerryLook 78 #1 Posted January 7 I have a 416H that I use with a front mount snow blower in the winter. Recently my driveway has been icy, so I thought I would see if the set of chains I have will fit on the 416. They fit, but both sides lightly rub on the metal side pieces next to the gas tank. Also the chain on the left is very close to the Hyd filter. The 416 has stock rear wheels, and stock size turf tires. 23x9.5x12. I was thinking if I could space the rear wheels out about 1/2” the chains would have enough space. Has anyone had to do this? I know they sell 5x4.5 wheel spacers online for pretty cheap. 1 Share this post Link to post Share on other sites
leabassett@sbcglobal.net 160 #2 Posted January 7 Do you have the chains on correct? My 312-8 has no problem with chains 1 Share this post Link to post Share on other sites
JerryLook 78 #3 Posted January 7 Yes they’re on correct. The chains were on a C-105 and they fit that just fine. On the 416H there isn’t a lot of room between the tires and the gas tank shields. Probably less than an inch on each side. Share this post Link to post Share on other sites
Ed Kennell 44,123 #4 Posted January 7 There is not much clearance on my 520. I always cut the inside side chain to the exact length and connect the ends with one of these connectors. Then pull the chains to the outside with the cam lock connector and install spring tensioners. This minimizes the thickness of the inside chain. 2 2 Share this post Link to post Share on other sites
kpinnc 16,654 #5 Posted January 7 4 hours ago, JerryLook said: Has anyone had to do this? I know they sell 5x4.5 wheel spacers online for pretty cheap. I won't say I had to, but I've used spacers on several machines. They work well but you do need to be careful if using a mower deck because of the deck gage wheels clearance. You'll have to ream your bolt holes on your wheels to 1/2. They type of spacer also needs to be open in the center to fit a WH hub. You'll also need to use 7/16x20 bolts at about 1 and 1/4 length or raised head studs to hold the spacers on. I've never had good luck using WH wheel bolts with spacers. The heads are usually too large to get a standard socket on them inside the spacer. 3 1 Share this post Link to post Share on other sites
Achto 30,510 #6 Posted January 7 A set of these & you should not need to ream out the holes in your rim. Just get longer wheel studs. https://www.jegs.com/i/JEGS/555/65058/10002/-1 3 Share this post Link to post Share on other sites
WHX?? 53,857 #7 Posted January 7 (edited) 8 hours ago, kpinnc said: won't say I had to, but I've used spacers on several machines. Custom tractor and just didn't look right with the tires inset. Plus to match the wide fronts. Yes the spacer studs were 1/2-20 but even with reaming the holes could go back to 7/16 hardware. Edited January 7 by WHX?? 1 3 Share this post Link to post Share on other sites
peter lena 9,646 #8 Posted January 7 @JerryLook https://www.acehardware.com/departments/hardware/chain-and-rope/rope-and-chain-accessories/5058225?store=19230&gclsrc=aw.ds&gad_source=1&gad_campaignid=20155423139&gbraid=0AAAAADtqLJGPLBeXuIt2iGux03D9tbXDr&gclid=Cj0KCQiApfjKBhC0ARIsAMiR_Iu2D7v0j8MhBz6IrV51_GuXH3S1E8G_556PG1fFp0z1IgY8-NJ7I7caAusZEALw_wcB like a 2" welded ring on the outside of the chain set up , very easy to add on extension springs with a thin flat screwdriver . elevated wheel so you can adjust / improve as you go , makes it simple , easy , pete Share this post Link to post Share on other sites
lynnmor 8,392 #9 Posted January 7 Is the end of your axle flush with the hub? Share this post Link to post Share on other sites
photoguy 160 #10 Posted January 7 I just drill the spot welds on wheel center move it in and plug weld easy if you have a Mig. Share this post Link to post Share on other sites
kpinnc 16,654 #11 Posted January 7 6 hours ago, Achto said: A set of these & you should not need to ream out the holes in your rim. Just get longer wheel studs. At 1/2 inch thick, those are not a bad option at all. 2 Share this post Link to post Share on other sites
sqrlgtr 1,812 #12 Posted January 7 (edited) 8 hours ago, Achto said: A set of these & you should not need to ream out the holes in your rim. Just get longer wheel studs. https://www.jegs.com/i/JEGS/555/65058/10002/-1 I use the same type but mine came from Miller tire and was a lot more $$$. Wish I had seen these earlier The ones I have are just for the small ford/Wheel Horse bolt pattern 5x4.5 Edited January 7 by sqrlgtr 1 Share this post Link to post Share on other sites
My_horse 59 #13 Posted January 7 When I bought my chains back in 2002 for the 314-8, they came with a 3/8” wheel spacer. I wasn’t comfortable with the amount of threads holding in the hub with the spacers on. I loosened the setscrews in the axle hub and slid it out 3/8”. 1 Share this post Link to post Share on other sites
JerryLook 78 #14 Posted January 8 I was looking at spacers similar to the ones from Jegs. I think that’s the route I’m going to take. Here’s a pic to show how close the chains are. I think a 1/2” will give it enough clearance to be good. I appreciate all the input 2 Share this post Link to post Share on other sites
lynnmor 8,392 #15 Posted January 8 25 minutes ago, JerryLook said: I was looking at spacers similar to the ones from Jegs. I think that’s the route I’m going to take. Here’s a pic to show how close the chains are. I think a 1/2” will give it enough clearance to be good. I appreciate all the input While it won't make much difference in clearance, I wonder if you installed the chains with the hooks biting the tires for a reason. 1 1 Share this post Link to post Share on other sites
pfrederi 19,508 #16 Posted January 8 (edited) 11 hours ago, lynnmor said: While it won't make much difference in clearance, I wonder if you installed the chains with the hooks biting the tires for a reason. Chains are mounted inside out hook ends should be away from the tire...it will move the chain a bit close to tire...maybe not enough but you won't know till you try. Edited January 8 by pfrederi 2 Share this post Link to post Share on other sites
Lee1977 7,509 #17 Posted January 8 (edited) 17 hours ago, My_horse said: When I bought my chains back in 2002 for the 314-8, they came with a 3/8” wheel spacer. I wasn’t comfortable with the amount of threads holding in the hub with the spacers on. I loosened the setscrews in the axle hub and slid it out 3/8”. If your axle has a Woodruff key moving the hub out is not a good idea. The hub and axle was designed for the set screw to center on the woodruff key. If moved it tilted the key and will allow the hub to move on out in the direction the hub was moved. It isn't much but the set screw is only holding on one side. Edited January 8 by Lee1977 2 Share this post Link to post Share on other sites
JerryLook 78 #18 Posted January 8 That was probably a poor pic to post. I have already removed the chains and just threw one over the tire to show the clearance. The distance between the tire and gas shield is about one chain link width. Share this post Link to post Share on other sites
JerryLook 78 #19 Posted January 8 The tires that came on the tractor were more rounded on the tread section. These tires are the same size as stock, but have more squared off shoulders. Share this post Link to post Share on other sites
JerryLook 78 #20 Posted January 8 I just measured it and I have 5/8” clearance between the tire and shield. With no chains installed. 1 Share this post Link to post Share on other sites
Lee1977 7,509 #21 Posted January 8 12 minutes ago, JerryLook said: The tires that came on the tractor were more rounded on the tread section. These tires are the same size as stock, but have more squared off shoulders. The 9.50 on my 520-H were like that, the 88 and 89 came with 7" wide rims. The 8 1/2" wide rims that came on later 520 would have more clearance. Share this post Link to post Share on other sites
JerryLook 78 #22 Posted 4 hours ago I ordered some spacers. I’ll update the thread once they get here and I get things installed. 1 Share this post Link to post Share on other sites
peter lena 9,646 #23 Posted 2 hours ago @ jerry look , have had to lift rear end and verify wat was hitting , used wide tie wraps , to snug up any questionable link spot , nothing major , but solved the issue , pete Share this post Link to post Share on other sites
