tmix61 92 #1 Posted yesterday at 02:07 AM Taking apart the transmission tomorrow hopefully putting it back together after replacing one needle bearing My question is what is the cam block pin engaged in the cam block not quite understanding that any help would be great Share this post Link to post Share on other sites
953 nut 63,513 #2 Posted yesterday at 12:59 PM Here is a picture of the cam plate (upside down), the direction control linkage has a ball shaped arm that slides up and down in the slot of the cam plate, that in turn moves the Sundstrand's direction and speed output. Share this post Link to post Share on other sites
tmix61 92 #3 Posted yesterday at 01:21 PM I don't see this plate I see where the shaft goes in and the fluid comes through the strainer Share this post Link to post Share on other sites
pfrederi 19,424 #4 Posted yesterday at 01:44 PM The cam block and pin discussed in the manual are not involved with a divorced system as on your D200. Your D200 should be a piston to piston unit not a hydro gear. Share this post Link to post Share on other sites
tmix61 92 #5 Posted yesterday at 01:47 PM Thank you very much for clearing that up wasn't quite sure what I was reading never been inside before. Just want to open it up and replace this one needle bearing Share this post Link to post Share on other sites
pfrederi 19,424 #7 Posted yesterday at 02:01 PM Did your kit include a new special sealing washer?? Share this post Link to post Share on other sites
tmix61 92 #8 Posted yesterday at 02:15 PM Motor installation is pretty straightforward I have a new gasket for the strainer. The old one was pretty crisp and a new gasket for the pump Share this post Link to post Share on other sites
tmix61 92 #9 Posted yesterday at 02:17 PM 15 minutes ago, pfrederi said: Did your kit include a new special sealing washer?? Do you mean when you put the manifold tubing back on? Share this post Link to post Share on other sites
pfrederi 19,424 #10 Posted yesterday at 02:19 PM (edited) 3 minutes ago, tmix61 said: Do you mean when you put the manifold tubing back on? Yes there was a washer under one of the front bolts that hold the manifold to the hydro motor. It is a sealing washer. Not sure it was designed to be reused... Edited yesterday at 02:21 PM by pfrederi Share this post Link to post Share on other sites
tmix61 92 #11 Posted yesterday at 02:25 PM Not sure which one you're talking about was it an o-ring? Are we talking about the upper middle small hole above the big one? Share this post Link to post Share on other sites
pfrederi 19,424 #12 Posted yesterday at 03:03 PM No it was a flat crush type washer. It goes through the manifold into the top of the hydro motor (yellow arrow.) Share this post Link to post Share on other sites
tmix61 92 #13 Posted yesterday at 03:08 PM Oh boy I don't remember seeing that Share this post Link to post Share on other sites
tmix61 92 #14 Posted yesterday at 03:18 PM 57 minutes ago, pfrederi said: Yes there was a washer under one of the front bolts that hold the manifold to the hydro motor. It is a sealing washer. Not sure it was designed to be reused... I believe they are talking on the top of the manifold where all the rubber o-rings are. Am I wrong? Share this post Link to post Share on other sites
tmix61 92 #15 Posted yesterday at 03:19 PM I don't see anything on the schematic Share this post Link to post Share on other sites
pfrederi 19,424 #16 Posted yesterday at 04:23 PM You are looking at the wrong Schematic. The D series were somewhat different 4-67 and 4-68 bolt and washer 1 Share this post Link to post Share on other sites
pfrederi 19,424 #17 Posted yesterday at 04:25 PM I have used some sealing washers from Mcmaster that have held up for years. Can mail you one if you need it 1 Share this post Link to post Share on other sites
tmix61 92 #18 Posted yesterday at 05:22 PM Yes please could you send me one. How do I pay you? Thomas Miksa W5629 Summit rd Norway Mi 49870 Share this post Link to post Share on other sites
pfrederi 19,424 #19 Posted yesterday at 05:30 PM 4 minutes ago, tmix61 said: Yes please could you send me one. How do I pay you? Thomas Miksa W5629 Summit rd Norway Mi 49870 They are cheap no payment will mail it tomorrow. When it comes to the manifold system the parts manual for the D series tractors is better than the Sunstrand manual. Share this post Link to post Share on other sites
