markseven 83 #1 Posted Saturday at 11:39 PM Mine fuel pump is leaking around the gasket it original . Tried tighten the screws still leaks . Do not want to buy an aftermarket one. Are they rebuildable and where to get the parts? 1 Share this post Link to post Share on other sites
ri702bill 10,882 #2 Posted Sunday at 12:03 AM What engine exactly?? Different engines, different options. 1 Share this post Link to post Share on other sites
Achto 30,405 #3 Posted Sunday at 01:02 AM https://www.amazon.com/Ciuouient-230675-Diaphragm-Rebuild-Compatible/dp/B0F1XYDS4B/ref=sr_1_4 1 Share this post Link to post Share on other sites
markseven 83 #4 Posted Sunday at 03:28 PM Its a kohler k301 12 hp It always starts and runs good But it always takes some time cranking it over before it fires. I ordered the kit hoping it helps. Thank you. 2 Share this post Link to post Share on other sites
Achto 30,405 #5 Posted Monday at 12:09 AM 8 hours ago, markseven said: I ordered the kit hoping it helps. If this does not fix your issue, then you might consider switching to an electric pump. They usually render faster cold starts. https://www.amazon.com/Electric-Universal-Pressure-Transfer-Carburetor/dp/B08PY7V2MM/ref=sr_1_4_pp Share this post Link to post Share on other sites
WHX?? 53,592 #6 Posted Monday at 03:44 AM 12 hours ago, markseven said: ordered the kit For the short money they are I keep one on the shelf. If the pump isn't too gunked up and check valves are good no need to buy a pricier then & now kit. I like to glass the pump halves as they can warp from over tightening. That said don't over tighten on a rebuild. 2 Share this post Link to post Share on other sites
kpinnc 16,458 #7 Posted yesterday at 03:32 AM 23 hours ago, WHX?? said: like to glass the pump halves as they can warp from over tightening. That said don't over tighten on a rebuild. Just did the same on mine. Prolly gonna be next week before I order a kit. Complicated for what they are... Share this post Link to post Share on other sites
