old tool 2 #1 Posted January 2 (edited) Has anyone found a replacement for the assist spring #110614, which has been NLA now for several years? That or has anybody measured spring OD., wire diamemeter and length inside the hooks on ends? Edited January 2 by old tool Share this post Link to post Share on other sites
Ed Kennell 44,951 #2 Posted January 2 I make mine from old garage door springs. 1 2 Share this post Link to post Share on other sites
peter lena 9,775 #3 Posted January 2 @old tool almost non existent now , but old car hood springs , would kill that , maybe an old bone yard close by ? 1 Share this post Link to post Share on other sites
lynnmor 8,634 #4 Posted January 2 Check with Wheel Horse Parts & More and ask if the 4629 spring is the same. Share this post Link to post Share on other sites
old tool 2 #5 Posted January 2 Sorry my mistake the part I need is not defined as the Lift Spring - just as spring . Item # 7 in parts lookup (44" two-stage snowblower, gear case and belt assembly diagram).Part #110614 1 Share this post Link to post Share on other sites
ebinmaine 77,397 #6 Posted January 2 2 hours ago, old tool said: Sorry my mistake the part I need is not defined as the Lift Spring - just as spring . Item # 7 in parts lookup (44" two-stage snowblower, gear case and belt assembly diagram).Part #110614 I can check mine tomorrow morning. Share this post Link to post Share on other sites
ebinmaine 77,397 #7 Posted January 3 8 hours ago, old tool said: Sorry my mistake the part I need is not defined as the Lift Spring - just as spring . Item # 7 in parts lookup (44" two-stage snowblower, gear case and belt assembly diagram).Part #110614 From doing a search here on Redsquare for that number I'm seeing that as the lower assist rod spring. Also seeing a lot of people not using them on hydro lift tractors, especially if they have the front lift spring. Share this post Link to post Share on other sites
ebinmaine 77,397 #8 Posted January 3 On 1/2/2026 at 11:05 AM, old tool said: 110614 I don't have one here to measure. We apparently were using the snowblower without that lower spring. Share this post Link to post Share on other sites
