peter lena 9,701 #101 Posted 2 hours ago @Achto looks like a penetrating oil soak down , clean cloth mineral oil , finish , no scrubbing of any kind , the patina will find itself , also note the frame corner underside 90 degree angle opportunity ? reduce rubber fuel line ? 5/16 steel brake line , also like STA BIL in all my fuels , no / zero debris in any related filters or carb bowls , never leave an empty tank , always ad an ounce or 2 , always trying something , if I had your shop space , I would be in more trouble than i,m already in , pete 1 Share this post Link to post Share on other sites
WHX?? 54,407 #102 Posted 2 hours ago I gotta believe this plow is original to the tractor??? 1 1 Share this post Link to post Share on other sites
squonk 45,327 #103 Posted 2 hours ago (edited) 33 minutes ago, WHX?? said: I gotta believe this plow is original to the tractor??? I thought they came with the side shifter model BD4271 with the foot pedal release. I know the 64 604 we had had the plow you pictured with the 702. Maybe they used both and was a buyer's choice? Edited 2 hours ago by squonk Share this post Link to post Share on other sites
Handy Don 15,737 #104 Posted 1 hour ago ’63 Blade was the last model with the foot-pedal release for rotation and the last time the quadrant was open at the top with close-spaced holes for three positions. Also first time trip springs had cast iron end-pieces. Blade Dozer 42in 1963 BD-4263 newer.pdf Starting in ’64, quadrant was enclosed (top and bottom) with handgrip actuated rotation release. Blade Dozer 42in 1964 BD-4264.pdf Share this post Link to post Share on other sites
