Stan50 244 #1 Posted December 22, 2025 Fresh owner of 312-8 here . This is my RD 42" deck,Are these blades in proper position? (Deck was cleaned already, this is first pic before cleaninig ). I have not sharpen blades yet but I will. Share this post Link to post Share on other sites
groundhog47 448 #2 Posted December 22, 2025 If you are referring to horizontal rotation degree position, my opinion is they are ok. Vertical height is mainly fixed by spindle shaft and a spacer washer. The cut height of course is a bit affected that way. A bent down/up blade, usually can kinda eye ball that, sloppy spindle mounting, or bad bearings would show up in cut appearance as well as bent or damaged gauge height wheels. Anyway it looks like it has all going good!!! "Have a great day every day" 4 Share this post Link to post Share on other sites
Ed Kennell 47,588 #3 Posted December 22, 2025 Rotational position is not factor on these belt driven 3 blade decks. Only the 2 blade gear drive decks need to be positioned correctly. 2 3 Share this post Link to post Share on other sites
