Hump 0 #1 Posted September 27, 2009 I have a 2007 GT classic that came with the electric pto, and I would like to convert it to the manual style. I have a 2-stage snow blower, and will have a rear tiller for it soon. I have already had trouble with the electric one, and want to know if it has/can be done, and what I need to complete the conversion. Thanks in advance for the assistance! Share this post Link to post Share on other sites
pfrederi 19,002 #2 Posted September 28, 2009 2007....way too new for me Look up your Kohler motor by spec number at the Kohler site and study the crankshaft bearings. If there are ball bearings no problem. if they are sleeve bearings (aka bushings) then look for a thrust bearing on the PTO end. (Probably a flat needle bearing). No thrust bearing you will have to put on an external bearing as WH did when they used B&S engines I am sure there will also be linkage and safety switch issues but 2007 is too new for me. Share this post Link to post Share on other sites
Hump 0 #3 Posted October 3, 2009 Has anyone done this? Share this post Link to post Share on other sites
wheel horse 1045 2 #4 Posted October 3, 2009 i did on the older kohler motor with no problem but im not familer with that Share this post Link to post Share on other sites
thehorse 221 #5 Posted April 22, 2013 Hump....did you ever convert your gt over to manual?????? Share this post Link to post Share on other sites
