WHX?? 58,126 #51 Posted December 18, 2025 Lol no but they do make excellent catch pans for transmissions & such. Shallow cake pans work good too and get em for a nickel at rummage sales. Share this post Link to post Share on other sites
peter lena 10,065 #52 Posted December 18, 2025 @WHX?? regularly had a chart on hose , o ring replacement matching ring composition to any related lubricant , SUPER LUBE ,BTW the lubricant helps stop the ROLLING OF A DRY O RING , as its made up making for a starting leak , used SUPER LUBE , hydraulic oil on o rings , temp ranges are very extreme 450 + , _ 60 , another thing you might consider , is to have a local truck repair shop , make up tube bent stress / areas , connecting to a freer straight run , they regularly bend tubing and make up hoses . repetitive problems are showing you the way . just my view of this , pete 1 Share this post Link to post Share on other sites
