My_horse 131 #1 Posted December 12, 2025 We got a few inches of snow over the last few days. Not enough for the snow blower on the GC 2410. But if I didn’t clean it up, it would be a mess. So I drug out the 314-8 and took the mower deck off. Put the front and rear wheel weights on and the chains. Gassed it up. Got my 42” plow put on. Couldn’t find the short lift link to go to the deck lift arm, so I made one out of a piece of garage door opener lift arm and a couple clevis pins. Done. I haven’t really ever plowed snow with the 314-8. Have a blower for it and always used that, until I got the blower for the GC. It worked great, and didn’t dig up the gravel driveway much. Good seat time today. 8 5 1 Share this post Link to post Share on other sites
ri702bill 13,067 #2 Posted December 12, 2025 19 minutes ago, My_horse said: Put the front and rear wheel weights on and the chains. I agree - rear weights for traction, front weights for steering with the plow angled. 7 Share this post Link to post Share on other sites
Achto 32,707 #3 Posted December 13, 2025 Not a great look, but walk behind snow blower tire make excellent steer tires. No added weight, goes where I point it. 9 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,521 #4 Posted December 13, 2025 7 minutes ago, Achto said: Not a great look, but walk behind snow blower tire make excellent steer tires. No added weight, goes where I point it. Love the Black Hoods!!! 1 Share this post Link to post Share on other sites
8ntruck 9,301 #5 Posted December 13, 2025 @Achto, would those front tires work better if you swapped the left for right to reverse the tread direction? Being driven tires instead of drive tires, the self cleaning action might work better. 1 Share this post Link to post Share on other sites
Achto 32,707 #6 Posted December 13, 2025 11 minutes ago, 8ntruck said: would those front tires work better if you swapped the left for right to reverse the tread direction? Being driven tires instead of drive tires, the self cleaning action might work better. They seem to work pretty good the way they are, never have an issue with them plugging up. Might be worth a try swapping them around though. 3 Share this post Link to post Share on other sites
Blasterdad 3,168 #7 Posted December 13, 2025 2 hours ago, Achto said: Not a great look, but walk behind snow blower tire make excellent steer tires. No added weight, goes where I point it. Careful...Looks like frozen poop, talk about a photo bomb! ROFL! 6 Share this post Link to post Share on other sites
JoeM 10,267 #8 Posted December 13, 2025 Sister tractors. Everyone must have one! Had these on for a while, just can't go on the concrete. 4 Share this post Link to post Share on other sites
mrc 1,119 #9 Posted December 13, 2025 Achto, i think those snowblower tires look good! Share this post Link to post Share on other sites
peter lena 10,065 #10 Posted December 13, 2025 @Achto noticei the plow swing rod fresh paint ? any mods to that ? that swing quadrant and squeeze lever mount area , is a total change for easy . smooth blade swing . just asking , pete Share this post Link to post Share on other sites
Brockport Bill 2,478 #11 Posted December 13, 2025 the blackhood C175 plowing seems to do the job with and without chains or weights -- each fall I install the plow on i think if i should use the chains or weights or even maybe invest in a more aggresive front tire winter tread -- but with smart plowing technique the horse seems to mostly function fine -- have not put the chains or weights on yet this season -- will wait to see if we get any big storms? I can always put the weights and chains on if a forecast says deep heavy snow coming????????? 4 1 Share this post Link to post Share on other sites
Achto 32,707 #12 Posted December 14, 2025 10 hours ago, peter lena said: noticei the plow swing rod fresh paint ? any mods to that ? that swing quadrant and squeeze lever mount area Did not get the swing rod or the handle to operate it with the plow. Made the handle, trigger lever, & linkage myself. Oh, the wire from the trigger handle to the triangle pivot was made from a wire coat hanger, been working great for several years now. 1 Share this post Link to post Share on other sites
peter lena 10,065 #13 Posted December 14, 2025 @Achto reason for question , the frame mounted , squeeze lever swing start point , works directly with the plow SWING QUADRANT SPRING , often refer to this issue , easy to get a firmer , more solid rod component , I also use a shoulder swing bolt , at lever swing , area , ? the smooth bolt shoulder , lets the lever work with ease , flat washer it up for exact easy control , use an elastic Lok nut to trap / perfect setting . very small adjustments with responses , and red spray grease , makes the squeeze lever / spring quadrant swing , work with ease . like a roller stool , doing this , makes it easier , and you can dial in easy function . mine is in use now for years , with no issues , also like lubricated blade face , for easy slide off . good plowing , pete Share this post Link to post Share on other sites
SylvanLakeWH 32,521 #14 Posted December 14, 2025 22 hours ago, Brockport Bill said: the blackhood C175 plowing seems to do the job with and without chains or weights -- each fall I install the plow on i think if i should use the chains or weights Never use chains on my C-105 and it plows 3 concrete drives just fine. I added weight last year and found slight improvement, but not worth keeping my HF crane off. 1 Share this post Link to post Share on other sites
sqrlgtr 3,932 #15 Posted December 14, 2025 On 12/12/2025 at 7:33 PM, 8ntruck said: @Achto, would those front tires work better if you swapped the left for right to reverse the tread direction? Being driven tires instead of drive tires, the self cleaning action might work better. Wouldn't they self clean and pile up in front of steer tires? Share this post Link to post Share on other sites
My_horse 131 #16 Posted December 14, 2025 Got another 5-6” last night, so I plowed again. I think 6”+ is going to be my threshold for using the blower. Anything less, and it’s easier to plow it. Ordered some electric gloves that won’t get here until Friday. Could have really used them today. Fingers can’t take the cold anymore. I was stopping and warming my hands a couple times in the exhaust coming out of the muffler. 1 1 Share this post Link to post Share on other sites
8ntruck 9,301 #17 Posted December 14, 2025 7 hours ago, sqrlgtr said: Wouldn't they self clean and pile up in front of steer tires? They would probably tend to self cleaning by pushing the snow out the side of the tires. Kind of like a F1 rain tire tread. Share this post Link to post Share on other sites
Retired Wrencher 6,989 #18 Posted December 15, 2025 It’s old, it’s ugly, but it still does the job after all these years. Just my two cents. 1 Share this post Link to post Share on other sites
sqrlgtr 3,932 #19 Posted December 15, 2025 46 minutes ago, Retired Wrencher said: It’s old, it’s ugly, but it still does the job after all these years. booty is in the eye of the beholder. I'd still take her out and dance with her Share this post Link to post Share on other sites
