FLtractor 78 #1 Posted 8 hours ago Morning, Wondering if there’s a recommendation dealer or place at a resonable price to get a Genuine Kohler points, Condenser and coil for my 856 to start my ignition system fresh and new. 2 Share this post Link to post Share on other sites
Gasaholic 341 #2 Posted 8 hours ago I get mine off Amazon - It does take a little careful research to be sure you're ordering genuine OEM , but they are still available. I buy amazon because of their strict return policy - if the seller ships me a non-OEM part I can return as "not as described" - some of them try to get around it by changing the wording in their description to something like "OEM Quality" but with a little critical thinking you can usually spot the actual OEM suppliers. Often they are known reputable businesses , distributors, etc. If I have any doubts or they are not being found on Amazon I'll go to Partstree or Ereplacement parts - even though I'm paying a price that is usually jacked up 15% to 20% above MSRP, it is worth it to me. There's also a number of sellers on Red Square that also sell on ebay or on their own websites where you can be pretty confident in getting the real thing. 2 Share this post Link to post Share on other sites
FLtractor 78 #3 Posted 8 hours ago 35 minutes ago, Gasaholic said: I get mine off Amazon - It does take a little careful research to be sure you're ordering genuine OEM , but they are still available. I buy amazon because of their strict return policy - if the seller ships me a non-OEM part I can return as "not as described" - some of them try to get around it by changing the wording in their description to something like "OEM Quality" but with a little critical thinking you can usually spot the actual OEM suppliers. Often they are known reputable businesses , distributors, etc. If I have any doubts or they are not being found on Amazon I'll go to Partstree or Ereplacement parts - even though I'm paying a price that is usually jacked up 15% to 20% above MSRP, it is worth it to me. There's also a number of sellers on Red Square that also sell on ebay or on their own websites where you can be pretty confident in getting the real thing. Do you happen to have a link to either the eBay or member websites ect that include the coil points and condenser so I know what exactly to get? How much should the coil alone cost these days? I was told back in April that a set of points and condenser should be about $18.00. 1 Share this post Link to post Share on other sites
Achto 30,124 #4 Posted 7 hours ago Personally, I would just clean up your old points. The material they use on the new points just don't seem to last like the old ones did. This can be said of the Kohler ones as well. 3 2 Share this post Link to post Share on other sites
FLtractor 78 #5 Posted 6 hours ago (edited) 1 hour ago, Achto said: Personally, I would just clean up your old points. The material they use on the new points just don't seem to last like the old ones did. This can be said of the Kohler ones as well. I’ll keep that in mind. I just put a brand new battery in my tractor this morning. does this mean it has good enough spark? Haven’t touched points.. Or do I need to clean the points and then look at spark plug light for different result? No gas currently in the tank. IMG_4816.mov Edited 6 hours ago by FLtractor 2 Share this post Link to post Share on other sites
Achto 30,124 #6 Posted 6 hours ago 13 minutes ago, FLtractor said: does this mean it has good enough spark? Looks good on the tester. I would still pull the plug & check to see if the spark looks good there. 1 Share this post Link to post Share on other sites
FLtractor 78 #7 Posted 6 hours ago 10 minutes ago, Achto said: Looks good on the tester. I would still pull the plug & check to see if the spark looks good there. Thank you. Will have to do that. 1 Share this post Link to post Share on other sites
rmaynard 16,687 #8 Posted 6 hours ago My last Genuine Kohler points were stamped "made in Mexico". There are not many Kohler engine parts made here in the USA anymore. 4 Share this post Link to post Share on other sites
ebinmaine 75,581 #9 Posted 2 hours ago 5 hours ago, Achto said: Personally, I would just clean up your old points. Seconded. Trina and I have had at LEAST 15 engines go through the shop now. I've replaced ONE set of points and quite likely didn't need to... My first thought on reading this thread was ... Why? 6 hours ago, FLtractor said: Kohler points, Condenser and coil for my 856 to start my ignition system fresh and new. Why do you believe you NEED new ignition? I believe you'd be FAR better off diagnosing an actual issue. As far as a good source, @Gasaholic has the right idea of safety in return capability. I personally feel that J Bezos has and wastes enough money so I've stopped buying most things from the jungle site. Not all. Most. I've been having very good experiences with a company called billsplaceshop.com Excellent customer service. Excellent prices. Many many OE parts. Definitely recommend them. 1 1 Share this post Link to post Share on other sites
FLtractor 78 #10 Posted 1 hour ago (edited) 1 hour ago, ebinmaine said: Seconded. Trina and I have had at LEAST 15 engines go through the shop now. I've replaced ONE set of points and quite likely didn't need to... My first thought on reading this thread was ... Why? Why do you believe you NEED new ignition? I believe you'd be FAR better off diagnosing an actual issue. As far as a good source, @Gasaholic has the right idea of safety in return capability. I personally feel that J Bezos has and wastes enough money so I've stopped buying most things from the jungle site. Not all. Most. I've been having very good experiences with a company called billsplaceshop.com Excellent customer service. Excellent prices. Many many OE parts. Definitely recommend them. When I last drove my 856 in April and it shut off and wouldn’t restart, I thought it’s either a fuel issue and or ignition perhaps both. I put new battery in today, got new fuel line all hooked up, put the tester on spark plug and to my amazement, it has spark, just thought i could replace the points coil and condenser to have a fresh starting point so unknown they will be ones I installed and not unknown time frame. But as you all have mentioned the orignal are better and just lightly clean them to begin with, keep it simple. So after this misdiagnosis of it NOT being a spark or ignition issue after all, so since that functions properly, I will concentrate on the carburetor., I now know it has a dirty ethanol fuel clogged carburetor.. and possibly a compression issue.. after I showed my neighbor who was 30 year Sears lawnmower mechanic that spark tester video.. he said it sounds as if low compression.. and asked if it smoked.. when I started it in April, it did smoke some yes.. so perhaps I need to buy a Kohler rebuild and attempt that myself? which I do not have the proper tools needed to bore the cylinders and other specialized tools. Or is there a drop in direct replacement predator engine I could use while learning to rebuild the K181 engine? Or just once carb is clean, drive it with non ethanol fuel until it won’t drive anymore, THEN focus on rebuild/replace? Edited 1 hour ago by FLtractor 1 Share this post Link to post Share on other sites
ebinmaine 75,581 #11 Posted 45 minutes ago 39 minutes ago, FLtractor said: Sears lawnmower mechanic Sears used mostly Briggs or Tecumseh engines. A Kohler engine sounds ... different. 39 minutes ago, FLtractor said: that spark tester video.. he said it sounds as if low compression.. and asked if it smoked They do sound that way. Because at start up, they are low compression. Kohler engines have a compression release to help with starting. There are others that do as well but a mid 60s Kohler has a very docile sound. 43 minutes ago, FLtractor said: Or just once carb is clean, drive it with non ethanol fuel until it won’t drive anymore, THEN focus on rebuild/replace? This. Get it running. Use it. Enjoy it. 1 1 Share this post Link to post Share on other sites
FLtractor 78 #12 Posted 43 minutes ago 1 minute ago, ebinmaine said: Sears used mostly Briggs or Tecumseh engines. A Kohler engine sounds ... different. They do sound that way. Because at start up, they are low compression. Kohler engines have a compression release to help with starting. There are others that do as well but a mid 60s Kohler has a very docile sound. This. Get it running. Use it. Enjoy it. Thank you very much. Will take Off old carb and install aftermarket while figure out what to do with orignal 1 1 Share this post Link to post Share on other sites
FLtractor 78 #13 Posted 31 minutes ago (edited) 5 hours ago, rmaynard said: My last Genuine Kohler points were stamped "made in Mexico". There are not many Kohler engine parts made here in the USA anymore. As someone new to Wheelhorse and who likes to support USA made when able, That’s disappointing to hear Edited 31 minutes ago by FLtractor Share this post Link to post Share on other sites
