FLtractor 134 #1 Posted December 9, 2025 (edited) Morning, I have an 856. Currently working on replacing fuel line, so completely drained of fuel. I want to check the deck spindles to see what shape and to know what else I need to make deck mow.. previous seller said need new spindles, gauge wheels… given the only fluid currently in tractor is engine oil and transmission… would it be safe to lift the tractor upwards with a winch by the front axel, enough to get a look under the deck? Would doing this potentially break or disrupt something mechanical with tractor or drain fluids where they shouldnt be? What is the recommended way to lift the tractor to do this? Would prefer to not have to remove deck if at all possible. Thank you Edited December 9, 2025 by FLtractor Share this post Link to post Share on other sites
ri702bill 11,521 #2 Posted December 9, 2025 Best to NOT try to use a floor jack under the middle of the axle, as there is an angled grease zerk fitting there - very easy to snap it off. I use a lifting strap around the frame near the engine - the top of the strap goes to a come-along on an overhead beam in the garage... Doing so it is then in the correct position to grease the axle pivot & spindles..... 3 1 Share this post Link to post Share on other sites
953 nut 64,608 #3 Posted December 9, 2025 If you lift the tractor far enough to INSPECT the spindles you won't have accomplished very much. Remove the deck and remove the spindle shafts to see what condition they are in. This manual will show you all the parts and pieces and be a good guide. Share this post Link to post Share on other sites
FLtractor 134 #4 Posted December 9, 2025 3 hours ago, ri702bill said: Best to NOT try to use a floor jack under the middle of the axle, as there is an angled grease zerk fitting there - very easy to snap it off. I use a lifting strap around the frame near the engine - the top of the strap goes to a come-along on an overhead beam in the garage... Doing so it is then in the correct position to grease the axle pivot & spindles..... Will keep the axel zerk in mind. Thank you Share this post Link to post Share on other sites
FLtractor 134 #5 Posted December 9, 2025 53 minutes ago, 953 nut said: If you lift the tractor far enough to INSPECT the spindles you won't have accomplished very much. Remove the deck and remove the spindle shafts to see what condition they are in. This manual will show you all the parts and pieces and be a good guide. Thank you. Is there a guide or video on deck removal and installation? Share this post Link to post Share on other sites
Ed Kennell 45,304 #6 Posted December 9, 2025 5 hours ago, FLtractor said: would it be safe to lift the tractor upwards with a winch by the front axel No problem for the tractor, but my material handling training taught me to never put a body part under a suspended load. 4 2 1 Share this post Link to post Share on other sites
ri702bill 11,521 #7 Posted December 9, 2025 4 minutes ago, FLtractor said: Thank you. Is there a guide or video on deck removal and installation? The RM-326 explains that. If you have that exact deck, do remove it and flip it over to check if the large housing casting is cracked near the middle. Very common. Share this post Link to post Share on other sites
FLtractor 134 #8 Posted December 9, 2025 10 minutes ago, Ed Kennell said: No problem for the tractor, but my material handling training taught me to never put a body part under a suspended load. I would just be taking pictures from a safe distance.. yet wanted to see what underneath looks like without removing but I will have to remove deck anyway Share this post Link to post Share on other sites
FLtractor 134 #9 Posted December 9, 2025 (edited) 13 minutes ago, ri702bill said: The RM-326 explains that. If you have that exact deck, do remove it and flip it over to check if the large housing casting is cracked near the middle. Very common. Started reading it before, just more of a visual learner. If the large middle housing is in fact cracked, what options would i have then? Whole new deck? Edited December 9, 2025 by FLtractor Share this post Link to post Share on other sites
1054 Project 44 #10 Posted December 9, 2025 Probably best to remove the deck if you want a good look. If you have a set of car ramps you can get a quick look. 1 Share this post Link to post Share on other sites
ri702bill 11,521 #11 Posted December 9, 2025 8 minutes ago, FLtractor said: Started reading it before, just more of a visual learner. If the large middle housing is in fact cracked, what options would i have then? Whole new deck? Options... Replace just the housing - if you have to go that route, be careful to get the right one. There were 32" decks and 36" decks. Each has its own casting... Furnace brazing the broken part. Generally not a backyard project. Cast iron requires pre-heating bot parts to prevent cracking after brazing as it cools... kind of a lost art. You need to see if both spindles are bent too. Those are heat treated hard thru - they will bend a bit before they break. If bent, they must be replaced. Bent spindles & a cracked housing are what happens when you hit a solid object while mowing with one of these... Again - pictures are needed to better understand what you have there... Share this post Link to post Share on other sites
WHX?? 55,672 #12 Posted December 9, 2025 5 hours ago, FLtractor said: Would prefer to not have to remove deck if at all possible. Your reasoning behind that? When a new to comes in here that is the first thing that comes off for a few reasons. Bit easier to service tractor.. Skools me on taking it on and off. Most if not all decks were designed to be easily taken on and off. Procedure should be in the deck manual. Best way to inspect/service deck. 3 3 Share this post Link to post Share on other sites
ri702bill 11,521 #13 Posted December 9, 2025 (edited) 1 hour ago, WHX?? said: Best way to inspect/service deck. That gives me a chance to look it over using the good eye!! Edited December 9, 2025 by ri702bill 1 1 Share this post Link to post Share on other sites
Pullstart 69,197 #14 Posted December 9, 2025 Another vote for pulling the deck. Good way to inspect the frame at the transmission mount, or “f plate” as well. 2 2 Share this post Link to post Share on other sites
ri702bill 11,521 #15 Posted December 9, 2025 55 minutes ago, Pullstart said: Another vote for pulling the deck. Good way to inspect the frame at the transmission mount, or “f plate” as well. We all have to be kind to our "f" plates.. unless you want a 2-piece tractor. 2 Share this post Link to post Share on other sites
adsm08 4,249 #16 Posted December 9, 2025 14 hours ago, FLtractor said: Would prefer to not have to remove deck if at all possible. You are going to cause yourself 5x the work trying to be lazy this way. I can have the decks off both of my WHs, which are identical to yours, in under a minute. That's from fully assembled, mowing tractor to deck standing up on its back for cleaning/inspection. You will waste at least 5 minutes trying to figure out where to place the jack. To get the deck off you slip the belt off the deck pulley, pull the lift-link pin, pull the pin from the frame mounting bracket, turn the wheels to the right, and pull the deck out from the left. You may need to lean on the tractor a bit to make the link clear the frame. Installation is the reverse, it helps to place the front anti-scalp wheel on a piece of 2x4, this holds the deck at the correct height to get it latched back in its bracket. Also, lets assume you get under it and get your inspection done with the deck on, and find all that work you were told it needs is actually needed. What then? You aren't doing those spindle bearings with the deck installed, the whole thing has to be torn down to bits and pieces. Share this post Link to post Share on other sites
FLtractor 134 #17 Posted December 9, 2025 9 hours ago, WHX?? said: Your reasoning behind that? When a new to comes in here that is the first thing that comes off for a few reasons. Bit easier to service tractor.. Skools me on taking it on and off. Most if not all decks were designed to be easily taken on and off. Procedure should be in the deck manual. Best way to inspect/service deck. Good point.. I know that would be best, just afraid I’ll get unhooked and not be able to rehook it after.. not as that should currently be frustrating to me given it doesn’t now currently anyway.. have bad habit of procrastination.. so I would probably take it off and not end up putting it back on. Least I’d learn underside of tractor and deck are like Share this post Link to post Share on other sites
FLtractor 134 #18 Posted December 9, 2025 (edited) 6 minutes ago, adsm08 said: You are going to cause yourself 5x the work trying to be lazy this way. I can have the decks off both of my WHs, which are identical to yours, in under a minute. That's from fully assembled, mowing tractor to deck standing up on its back for cleaning/inspection. You will waste at least 5 minutes trying to figure out where to place the jack. To get the deck off you slip the belt off the deck pulley, pull the lift-link pin, pull the pin from the frame mounting bracket, turn the wheels to the right, and pull the deck out from the left. You may need to lean on the tractor a bit to make the link clear the frame. Installation is the reverse, it helps to place the front anti-scalp wheel on a piece of 2x4, this holds the deck at the correct height to get it latched back in its bracket. Also, let’s assume you get under it and get your inspection done with the deck on, and find all that work you were told it needs is actually needed. What then? You aren't doing those spindle bearings with the deck installed, the whole thing has to be torn down to bits and pieces. Fair points.. it’s the part inside my head that’s afraid I won’t put it back on or get it halfway off and stuck somehow. Just have too many projects I attempt to work on all at once I get overwhelmed. Need to start small . One at a time. Need to do as you and others said, thank you for the walkthrough. The anti scalp wheel is the longer black.. rubber? Wheel attached to deck front? Edited December 9, 2025 by FLtractor Share this post Link to post Share on other sites
adsm08 4,249 #19 Posted December 9, 2025 16 minutes ago, FLtractor said: Fair points.. it’s the part inside my head that’s afraid I won’t put it back on or get it halfway off and stuck somehow. Just have too many projects I attempt to work on all at once I get overwhelmed. Need to start small . One at a time. Need to do as you and others said, thank you for the walkthrough. The anti scalp wheel is the longer black.. rubber? Wheel attached to deck front? 1) Ritalin. 2) Yes, anti-scalp wheel is the really wide/long one on the front. Not sure what the original material was, mine is hard, plastic-ey, possibly a petrified form of some other material. Share this post Link to post Share on other sites
FLtractor 134 #20 Posted December 10, 2025 11 minutes ago, adsm08 said: 1) Ritalin. 2) Yes, anti-scalp wheel is the really wide/long one on the front. Not sure what the original material was, mine is hard, plastic-ey, possibly a petrified form of some other material. 1. There is that to consider. 2. yea the plastic rubbery wheel roller Thank you again Share this post Link to post Share on other sites
c-series don 11,660 #21 Posted December 10, 2025 Is that called an F plate because one might look under the tractor and say “The F in plate is cracked?” 7 1 Share this post Link to post Share on other sites
