edgcooper 18 #1 Posted December 8, 2025 I recently purchased this extension for a snow plow but don't know what model WH it is meant for. 4 inches longer than one for a 520H. Any of you experts have an opinion? 1 Share this post Link to post Share on other sites
ri702bill 11,629 #2 Posted December 8, 2025 Is that the part to extend the plow forward about 4" when you have a model like the 520H with the HD forward swept front axle?? Certainly, looks like it... 1 Share this post Link to post Share on other sites
edgcooper 18 #3 Posted December 8, 2025 Yes, this is a extension for a plow frame but information I have found here on the forum it is 4" longer than the correct one. Pictures on forum showing dimensions of correct extension overall is 12 1/4 inches. This extension is 16" overall as shown in pictures. I tried using this on my frame but puts the bracket for pivot lever to far front which hits steering linkage when raising plow frame up. Was advertised as extension for 520 WH. I have a 1994 520H. 1 Share this post Link to post Share on other sites
ebinmaine 78,032 #4 Posted December 8, 2025 Maybe a 200 series? Or another implement altogether? 1 Share this post Link to post Share on other sites
Handy Don 16,143 #5 Posted December 8, 2025 (edited) 2 hours ago, edgcooper said: Was advertised as extension for 520 WH. Unless it was for adapting a standard 3-,4-, or 5-series plow to work on a 520xi? The xi’s have longer wheelbases 52" inches vs. 47.5 for the 520-H (not swept) -- a difference of 4.5 inches Edited December 8, 2025 by Handy Don 2 Share this post Link to post Share on other sites
JoeM 9,718 #6 Posted December 9, 2025 the pics show measurements of the plow frames, distance taken from the swivel bolt in the front. Difference of lifting attachment points, xi is 52 1/2 Also the standard plow handle will need modified for use on the xi because the running boards are wider and different. 1 Share this post Link to post Share on other sites
edgcooper 18 #7 Posted December 9, 2025 Thanks Don & Joe. I think the info you two have presented shows that the extension I have is for 3, 4 and 5 series plows to use on the XI series tractors. It seems to be the only explanation. Has any of you ever seen or heard of this extension being available? 1 Share this post Link to post Share on other sites
Handy Don 16,143 #8 Posted December 10, 2025 21 hours ago, edgcooper said: Has any of you ever seen or heard of this extension being available? I haven’t, but I’ve not had much contact with the xi machines. That said, it makes perfect sense to me that Toro would make a few fairly inexpensive parts to adapt a widely-available “standard” dozer blade rather than make an xi-specific frame. The xi’s were not a high-volume product line. Share this post Link to post Share on other sites
edgcooper 18 #9 Posted December 10, 2025 Now do I try to sell it or cut it down to correct length for me to use for my 94 520H? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,097 #10 Posted December 10, 2025 There was a retrofit kit to use the 300-500-Series blade on the 5xi but looks like it was the 5xi frame only so the older blade could be added. No extension included. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,097 #11 Posted December 11, 2025 Wonder if it is this one? 1 Share this post Link to post Share on other sites
Handy Don 16,143 #12 Posted December 11, 2025 5 hours ago, edgcooper said: Now do I try to sell it or cut it down to correct length for me to use for my 94 520H? My first instinct would be to add an extra ¾” rod through the side plates at the distance you need for your tractor and let the thing hang out the back 1 Share this post Link to post Share on other sites
edgcooper 18 #13 Posted December 11, 2025 That extension shown in the picture submitted by gwest-ca certainly looks just like the extension I have. Thank you everyone! Share this post Link to post Share on other sites
Opie55 0 #14 Posted December 24, 2025 I fabricated an extension to mount an earlier model snow plow to my 518xi. I don’t recall dimensions but the plow does clear the tires by about 2” at both angle settings. Share this post Link to post Share on other sites
sqrlgtr 2,422 #15 Posted January 9 On 12/10/2025 at 5:27 PM, edgcooper said: Now do I try to sell it or cut it down to correct length for me to use for my 94 520H? If it were me I would try and find correct bracket and not molest that one, but sometimes you just gotta do what you gotta do. Share this post Link to post Share on other sites
