markseven 93 #1 Posted December 8, 2025 For all the guys that have these tractors Im curious how do the hydro transmissions hold up i mean there like 50 to 60 years old now. 🤔 just wondering 1 Share this post Link to post Share on other sites
JoeM 9,671 #2 Posted December 8, 2025 If they have had reasonable care, real well. Reasonable care is cleaning the cooling fins, making sure the fan is working good, and oil changes. Especially the Eaton 11 that has filtration in front of the oil feeding the charge pressure to the pump and hold up well. 7 Share this post Link to post Share on other sites
Ed Kennell 45,304 #3 Posted December 8, 2025 I have had a couple Sundstrands get weak. Never had a problem with the Eaton 1100s. 5 Share this post Link to post Share on other sites
953 nut 64,608 #4 Posted December 8, 2025 All depends on how they were used or abused. If well maintained the Sundstrand and Eaton 1100 will continue to operate for several more decades. 7 Share this post Link to post Share on other sites
kpinnc 17,482 #5 Posted December 8, 2025 1 hour ago, 953 nut said: All depends on how they were used or abused. If well maintained the Sundstrand and Eaton 1100 will continue to operate for several more decades. My 1971 Bronco had a OEM filter when I got it around 2004, so it may have never been changed. That Sundstrand hydrogear still has ATF in it and it is the fastest and strongest hydro like it that I've seen so far. My FILs Charger is a 1972 and is nearly as fast. Also always had ATF in it as far as I know. I've been inside the Bronco transmission, and it was not only spotless but it had zero visible wear. I've always attributed this to ATF- but I'll never know. So the answer to your question has already been said: with proper use and maintainence, these old transmissions last decades. 1 3 2 Share this post Link to post Share on other sites
squonk 45,789 #6 Posted December 8, 2025 I have had problems with both Sunstrand and the Eaton. I bought my C-160 with 700 hrs. on it. Shortly after it started to get erratic and bucking like a wild horse. I had to replace the hydro motor. I use this tractor for mowing and on hot days it gets a little weak. Running Mobil 1 10W-40 helps quite a bit. When I bought a C-145 with the Eaton it would barely move when warmed up. I found a complete unit at the show that fixed that. I've had 2 hydrogears. both are/were excellent. Sold one. My current 875 is very responsive and strong. Tractor had a broken frame at the mounting area as it towed a firewood trailer most of it's life 4 Share this post Link to post Share on other sites
pfrederi 20,047 #7 Posted December 8, 2025 I only have two Eatons but several Sunstrands. I think the piston to piston Sunstrands are more sensitive to abuse/poor maintenance. The Eatons require some warm up to operate the lift even with Mobil one synthetic. The sunstrands are ready to go immediately I run ATF in them. Keep them from overheating, don't abuse the parking brake in the Sunstrands, and change the fluid and they will run another 30 years... 5 Share this post Link to post Share on other sites
rjg854 12,888 #8 Posted December 8, 2025 I have a '76 C160, that came out of a hedgerow, I use for snow plowing and mowing. The transmission still seems fine even going up the hill of the driveway that's somewhat steep. I also have a '73 16 Auto that is a dedicated snow blower, that one moves just as well. I do let them warm up a little, but could if I wanted to, take right off with either one in the cold and hydraulics work just fine. 2 1 Share this post Link to post Share on other sites
Ed Kennell 45,304 #9 Posted December 8, 2025 4 hours ago, pfrederi said: The Eatons require some warm up to operate the lift even with Mobil one synthetic. This is a strange quirk of some of the Eaton 1100s. I have some that will lift immediately and others require a lengthy warm up. All lift and pull strong after warm up. Wheel Horse does recommend a warm up of all Eatons. 2 Share this post Link to post Share on other sites
JoeM 9,671 #10 Posted December 8, 2025 1 hour ago, Ed Kennell said: This is a strange quirk of some of the Eaton 1100s Even more strange, the toro xi's use the 1100 and they pick right up. Out of all 6 that I have run they all pick right up. I changed an xi hydro that had the internal damping piston o rings compromised. I used a 1100 that came out of a 520. Sure enough it had a delay when cold. I looked at both charge pumps and could not see any difference. Pretty much stumped. Almost threaten to use install the xi's charge pump on the 520 hydro. 2 Share this post Link to post Share on other sites
Handy Don 16,049 #11 Posted December 8, 2025 1 hour ago, JoeM said: Even more strange, the toro xi's use the 1100 and they pick right up. Out of all 6 that I have run they all pick right up. I changed an xi hydro that had the internal damping piston o rings compromised. I used a 1100 that came out of a 520. Sure enough it had a delay when cold. I looked at both charge pumps and could not see any difference. Pretty much stumped. Almost threaten to use install the xi's charge pump on the 520 hydro. When the Eaton “cold” and not picking up, is motion also sluggish? Share this post Link to post Share on other sites
JoeM 9,671 #12 Posted December 8, 2025 1 hour ago, Handy Don said: When the Eaton “cold” and not picking up, is motion also sluggish? I know the one 520 was sluggish or would not move. As far as the xi, it uses the charge oil for the power steering, even if it moves you have no steering. (or I should say limited steering) I never tried it. Share this post Link to post Share on other sites
ineedanother 1,968 #13 Posted December 8, 2025 I have two Sunstrands. One on a '73 with a K341 and 10 pinion L/S that will spin both rears with lugged tires. The other came on a '75 c-160 that was run hard. Busted F-bracket and trashed keyways in both axles. It seemed good internally with clean fluid so I tore it down and replaced the axles. The pump and motor were in great shape so I just cleaned up the slippers and it's a spare now, likely good for many more years if I ever need it. 4 1 Share this post Link to post Share on other sites
