Krice58 181 #1 Posted December 4, 2025 Top mounting hole in my c160 belt guard is blown out and I can’t find a replacement. Anyone have any tips for repair? Just weld a washer in? Any input would be great. Thanks. I’ll include some pictures of my issue. This isn’t my belt guard in the photos but it’s the same issue. 1 Share this post Link to post Share on other sites
ebinmaine 80,710 #2 Posted December 4, 2025 2 minutes ago, Krice58 said: I can’t find a replacement You check with Lincoln at A to Z in pennsylvania? 2 minutes ago, Krice58 said: Just weld a washer in I believe that to be a pretty good idea. Get a fairly thin Fender washer with the correct diameter hole. Use something close to the thickness of your existing sheet metal to make the weld easier. Place, cut, trim, form the fender washer and paste it in place. 4 1 Share this post Link to post Share on other sites
ri702bill 13,067 #3 Posted December 4, 2025 Or .... remove the entire top piece with the 2 holes, replace it with thin gage angle mounted from under the inside, Weld, bond, or screw it together. 4 Share this post Link to post Share on other sites
Ed Kennell 47,351 #4 Posted December 4, 2025 (edited) I used a piece of 1/16" thick angle iron cut to the shape of the broken piece. Cut out the damaged part and welded the new part in place. Oops, Bill types faster. Edited December 4, 2025 by Ed Kennell 4 Share this post Link to post Share on other sites
Krice58 181 #5 Posted December 4, 2025 22 minutes ago, ebinmaine said: You check with Lincoln at A to Z in pennsylvania? I’ll have to give him a call. There’s only an eBay store for them now, the main site is shut down and I didn’t see anything on the bay, but I’m sure he has a whole lot more that’s just not listed there yet. 2 Share this post Link to post Share on other sites
Krice58 181 #6 Posted December 4, 2025 9 minutes ago, ri702bill said: Or .... remove the entire top piece with the 2 holes, replace it with thin gage angle mounted from under the inside, Weld, bond, or screw it together. Sounds like a good idea. 2 Share this post Link to post Share on other sites
Krice58 181 #7 Posted December 4, 2025 7 minutes ago, Ed Kennell said: I used a piece of 1/16" thick angle iron cut to the shape of the broken piece. Cut out the damaged part and welded the new part in place. Oops, Bill types faster. That may be a better solution than welding to the already rusted and damaged metal. 2 Share this post Link to post Share on other sites
ebinmaine 80,710 #8 Posted December 4, 2025 1 hour ago, Krice58 said: I’ll have to give him a call. There’s only an eBay store for them now, the main site is shut down and I didn’t see anything on the bay, but I’m sure he has a whole lot more that’s just not listed there yet. Lincoln is too busy to run a website. Doesn't matter to me where it's posted online. Who hosts. I'll never do anything but use the telephone to get a hold of him. 2 Share this post Link to post Share on other sites
squonk 48,126 #9 Posted December 4, 2025 Washer Boom Shaka Laka 2 1 Share this post Link to post Share on other sites
953 nut 69,322 #10 Posted December 4, 2025 2 hours ago, Krice58 said: Just weld a washer in? Share this post Link to post Share on other sites
Treepep 1,151 #11 Posted December 4, 2025 3 hours ago, Krice58 said: I’ll have to give him a call. There’s only an eBay store for them now, the main site is shut down and I didn’t see anything on the bay, but I’m sure he has a whole lot more that’s just not listed there yet. Important! Always call Lincoln my friend. Website has always been like flippin through the paper at the auto store to find what part you need. If I were a better welder I would attempt the fix. Probably would anyway Best of luck either route! 1 Share this post Link to post Share on other sites
Horsin'round 482 #12 Posted December 5, 2025 There seems to be an abundance of spare parts requiring this repair. I replaced the entire fin with new metal. Layed a big fat ugly bead of weld in the crease, an ground it back slightly concave (the weld). Given the location, it's not really noticeable. 1 Share this post Link to post Share on other sites
