wh315-8 641 #1 Posted December 3, 2025 (edited) Had a great Time with my RJ pushing 4” of wet snow. Pushed with ease even without weights or chains, but ground isn’t frozen solid yet. Tried to represent those old ads of those Pipe Smokers. Edited December 3, 2025 by wh315-8 Typo fix 7 8 9 Share this post Link to post Share on other sites
Handy Don 17,516 #2 Posted December 4, 2025 Completely awesome! And thanks for including the early ads. 1 1 Share this post Link to post Share on other sites
wh315-8 641 #3 Posted August 6 Update to this early dozer setup. Have it all cleaned up and painted for showings. 9 Share this post Link to post Share on other sites
ML3 2,533 #4 Posted August 6 (edited) Heres plow setup on my RJ. The handle on right side is what angles the blade after the right pedal is depressed to release the pin. Working this summer on blasting & painting plow to make it look as nice as the tractor Edited August 6 by ML3 4 5 Share this post Link to post Share on other sites
wh315-8 641 #5 Posted August 6 (edited) 1 hour ago, ML3 said: Heres plow setup on my RJ. The handle on right side is what angles the blade after the right pedal is depressed to release the pin. Working this summer on blasting & painting plow to make it look as nice as the tractor That’s the HD42, I have that style also, works in the 60/61 models also. Foot pedal on right side also on the first version. And a rope on top of blade to pull it left or right angle, I like your addition, that arm is a great idea. Edited August 6 by wh315-8 Add comments 3 1 Share this post Link to post Share on other sites
ML3 2,533 #6 Posted August 6 1 hour ago, wh315-8 said: That’s the HD42, I have that style also, works in the 60/61 models also. Foot pedal on right side also on the first version. And a rope on top of blade to pull it left or right angle, I like your addition, that arm is a great idea. I dont know anything about it. As you see it is how my setup was when I bought it from @Buckeyes 1 Share this post Link to post Share on other sites
Handy Don 17,516 #7 Posted August 6 1 hour ago, wh315-8 said: Wow. I hadn’t seen the “rope angle” mechanism before. Talk about basic yet functional! And all with around 5hp! My neighbors with giant snowblowers (or paying to have their driveways plowed) cannot comprehend an 8hp tractor’s capabilities. Go WH! 1 Share this post Link to post Share on other sites
ML3 2,533 #8 Posted August 6 1 hour ago, Handy Don said: My neighbors with giant snowblowers (or paying to have their driveways plowed) cannot comprehend an 8hp tractor’s capabilities. Yep! My 654 will push way more snow than my neighbors box store 22hp green tractor. 1 1 Share this post Link to post Share on other sites
wh315-8 641 #9 Posted August 7 10 hours ago, Handy Don said: Wow. I hadn’t seen the “rope angle” mechanism before. Talk about basic yet functional! And all with around 5hp! My neighbors with giant snowblowers (or paying to have their driveways plowed) cannot comprehend an 8hp tractor’s capabilities. Go WH! My C85 with a K181 8hp throws every bit of 30 feet and 14” of snow. My RJ59 and 400 Suburban plows just as easily with 4hp K91. IMG_1265.mov 3 Share this post Link to post Share on other sites
Handy Don 17,516 #10 Posted August 7 6 minutes ago, wh315-8 said: My C85 with a K181 8hp throws every bit of 30 feet My point exactly! ‘course we don’t see any of that powder stuff here. It’s alway somewhere between damp and slushy. Hence plow not blow. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,494 #11 Posted August 7 Is this RJ blade 36" wide? There was a SPR-36 available in 1955 with little else known about it. It was followed by model SPR-42 1956-1959 and HD-42 1959-1960 which became BD-4261 in 1961. Share this post Link to post Share on other sites
wh315-8 641 #12 Posted August 7 (edited) 53 minutes ago, gwest_ca said: Is this RJ blade 36" wide? There was a SPR-36 available in 1955 with little else known about it. It was followed by model SPR-42 1956-1959. It is 42” wide. Note: I made up the decal and serial number tag that’s on it, neither is necessarily period correct. I had bought the RJ with the frame bracket already on it. It had been on most likely since new because the id tag was partially there and good red paint under it, unfortunately id tag numbers were worn off. I have seen on The forum others that have this same setup. I found the blade and frame (ironically without the part I already had on the tractor) and it all came together. The owner of the blade only knew that it had been on a WH he ran around on as a teenager. Edited August 7 by wh315-8 Add comments 1 Share this post Link to post Share on other sites
sqrlgtr 4,035 #13 Posted August 7 I wouldn't care to see close up of pedal/chain setup that pulls the pin for angle adjustments if anybody has some. I have a dozer blade for my 550 and I have always just got off tractor to change angle and it's kinda a pain. I didn't realize what I was missing until I got blades that had the handle to chang the angle on them.... Share this post Link to post Share on other sites
wh315-8 641 #14 Posted August 10 (edited) On 8/7/2026 at 4:56 PM, sqrlgtr said: I wouldn't care to see close up of pedal/chain setup that pulls the pin for angle adjustments if anybody has some. I have a dozer blade for my 550 and I have always just got off tractor to change angle and it's kinda a pain. I didn't realize what I was missing until I got blades that had the handle to chang the angle on them.... Here is the manual showing the right pedal. If you enlarge my update picture, you can see what I did. I made the pedal, real simple to make. It basically is just free floating but enough slack to keep it forward of the foot peg. I put a spacer on the inside and flat steel with a 3/4” hole and a locking collar on the outside to keep it in place. Edited August 10 by wh315-8 Add comments 1 Share this post Link to post Share on other sites
