FLtractor
Tires for 856 Wheelhorse question
FLtractor
Will these fit a 856 23x8x12.. worth the $ for what they are? 200 mile roundtrip drive
Only pictures from listing.
Thank you
adsm08
Probably not. They are too narrow to fit the factory wheels, and those look like 6-lugs, the originals for an 856 are 5-lug.
ebinmaine
Doesn't seem so.
The 8.8- 22 is likely the size.
Quite a bit bigger than your own.
22 is the rim size.
FLtractor
3 minutes ago, ebinmaine said:
Doesn't seem so.
22 is the rim size.
The add says 8.8-22. Can you tell me what that number means in relation to my 856 rear of 23x8x12? What would or should I go with?
FLtractor
4 minutes ago, ebinmaine said:
Doesn't seem so.
22 is the rim size.
Thank you for prompt reply
ebinmaine
I'm not positive here....
I believe the 8.8 is the "advertised width" of the tire. The 22 should be the wheel diameter.
Many (most?) Garden Tractor tires are on a 12" wheel.
The middle number is the width.
The first number is the outer diameter of the tire.
There are a few tires that don't get even remotely close to the actual size with their advertised size.
You may very well find that getting two new tires is far easier and less expensive than shopping for usable used ones.  Factor in your own time and fuel.
  • Like 5
ri702bill
:text-yeahthat:Deestones are notorious for running on the SMALL end of the scale...
ri702bill
That size is not original to a 856. The 6-12 would be Those are from a later tractor like a B or C series - and the wider tires DO give you a wider track and more stability. New same size as what you have tires may be the way to go.
Edited by ri702bill
FLtractor
So Orginal wheelhouse size tires for my 856 would be 23x6x12? Given I may eventually very well may need both rear tires AND wheels given how rusty they are from the calcium chloride? Filled, is there a certian place new that’s highly recommended for getting the needed Wheelhorse wheels and tires together these days?
Edited by FLtractor
ri702bill
Calcium chloride is the rim killer over time. Attracts moisture and rots the rims from the inside out.... Rimguard (beet juice) does not.
Look at pictures of other 856's - and the IPM parts list to verify the original tire & rim size. Your tractor, your choice.
Most folks pick up a pair of used rims and new tires of their choice. Then mount them at home...
Edited by ri702bill
sqrlgtr
9287FD15-8A4C-457A-99AE-B39A1C547009.jpeg.ed7aefe96fa22e8ca0be819a33a975b5.jpeg012B3822-E665-4833-B9B5-31C439B05F61.jpeg.d2b717efd14257f3d6b9b02b5ed40050.jpeg
here is couple pics I posted a while back of my 856 on the difference between Deestone and Carlisle tires both 23x8.50x12 on same size rim. Ive had good luck with the deestones but you can see how much smaller they run.... They are usally quite a bit cheaper though.
FLtractor
Thank you for the measurements and info. Do you or someone else know if this is a legit website? Says they’ve sold over 1 million tires and prices seem very cheap. Giga-tires.com
Accidentally posted this vice grip garage video I was watching and can’t figure out how to remove it.
Edited by FLtractor
wallfish
Not sure that 3/4" to 1" of difference is a large amount but that could probably be made up with tire pressure. :twocents-02cents:
sqrlgtr
:jaw: I don't want to be around when you try and make them Deestones as big as the Carlisles by putting more air in them.:scared-eek: :ychain:
Retired Wrencher
Another great video by vice grip garage he is a bit  quirky,but he knows what he is doing. I enjoyed all his vid`s. Thanks @FLtractor for posting this.
Edited by Retired Wrencher
adsm08
Using the amazing Google Machine I have found the following:
Giga-tires has a Walmart vendor store, so they exist to some degree. They do not seem to be a reputable or reliable seller based on this Reddit thread:
https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://www.reddit.com/r/tires/comments/18ypzjy/is_gigatires_a_reputable_place_to_buy_from_they/&ved=2ahUKEwiw4t-e-qORAxW3kIkEHXm-CDoQFnoECBQQAQ&usg=AOvVaw1gdGDEryEqtDPotMtesMVl
I know those prices are great, but I would find somewhere else to buy.
Edited by adsm08
702854boy
When I was mounting our deestones, they said they had a max inflation of 35 psi, boy would that be a bumpy and hard ride :text-bump:
702854boy
There's nothing wrong with some Vice Grip Garage
ebinmaine
Ain't very big but remember that's all the way around the tire.
